Old 10-01-2011, 05:44 PM   #1 (permalink)
Sweetie - '011 Sonata GLS
90 day: 37.06 mpg (US)
HONKR - '94 KLX686
90 day: 59.94 mpg (US)
Screwed up
I have been playing with my motorcycle for the past few months and have neglected one detail on my car....... you guessed it, tire pressure.
Can't really say that I felt something was wrong because your brain adjusts slowly to a slow change, but my coast distances seemed 'off' and I did not think the tires would have lost SO much pressure. They looked fine, but when I applied the gauge to them this morning I was shocked they were 10 psi off what I normally run them at, and 4 psi under where you initially feel the coastability difference.
So, aired them up and just releasing the clutch I could feel the rolling difference.
Was even more shocked when rolling through the neighborhood.
Before getting back into motorbikes, I checked the pressure every other day.
It makes a massive difference, so keep track of it.
This ain't a war, anymore than a war between men and maggots. Or, dragons and wolves. Or, men riding dragons, throwing wolves at maggots!
Old 10-01-2011, 07:04 PM   #2 (permalink)
Efficiency Aficionado
CigaR007's Avatar
GreenTurtle - '01 Echo Sedan
90 day: 42.53 mpg (US)
Mine too were low by as much as 10 psi.
Old 10-01-2011, 07:21 PM   #3 (permalink)
Rick323's Avatar
tacoma - '05 Tacoma 4x4 TRD
90 day: 21 mpg (US)
The silver boat - '99 F250 xlt
90 day: 19.93 mpg (US)
Bluebird - '04 sunfire se
90 day: 37.56 mpg (US)
Versys - '08 versys
90 day: 57.43 mpg (US)
I used my truck a month or so ago to get some firewood. I didn't check the tire pressure before I used it. When I was in the woods, I just thought my tire was parked on a rock or something, it looked flat. Finally after moving the truck and the tire still looking flat, I decided it was flat. I nursed it home (7 miles) and tire pressures were as follows--45psi (normal), 25psi, 20psi, and the flat one 12psi. Before using the truck for firewood, the truck sat for a month and a half in my barn.
Old 10-01-2011, 07:35 PM   #4 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
...somebody (other than OnStar™) needs to market a "Tire Pressure" app for smart-phones!
2011 Chevrolet Cruze LTZ 1.4LT 6A
2009 Pontiac Vibe 1.8L/SFI 4A
2004 Pontiac Vibe 1.8L/MFI 4A
2003 Ford Focus ZX5 2.0L/Zetec 4A
1971 Dodge Charger 318 3A
1970½ Plymouth AAR 'Cuda 340/6BBL 4M
1968 Dodge Charger 383 3A
1967 Plymouth Barracuda Formula S 383 4M
1965 Plymouth Barracuda Formula S 273 4M
Old 10-01-2011, 07:56 PM   #5 (permalink)
mcrews's Avatar
The Q - '02 Q45 Sport
90 day: 23.08 mpg (US)
why dont you just 'schedule an appointment' with your tires on your calander??
ECO MODS PERFORMED:
First, Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Second, Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
third, rear skirts and 30.4mpg on trip! http://ecomodder.com/forum/showthrea...tml#post247938
Old 10-01-2011, 07:58 PM   #6 (permalink)
Vulcan - '05 Vulcan 500 LTD
90 day: 60.08 mpg (US)
Mag Pearl - '011 Fiesta SE Hatch
90 day: 45.91 mpg (US)
My 2008 Altima sat for 10 months before we finished repairing it and got it back on the road. I was amazed that the tire pressure monitoring system did not show a single tire to be low on air. I keep them at 40 PSI and have never seen them loose more than maybe 1 PSI a month.
My experience has been that when you change tires it's a good idea to clean the bead seating portion of the rim very carefully to make sure there are no rubber fragments left from the previous set of tires.
Seems to make a difference in long term pressure retention, if you actually have the opportunity to thoroughly clean the bead portion of the rims, as well as the area where the valve stem seats on the rim, especially on older cars and trucks.
Slow leaks can be hard to find, but the old sink it in a water tub will still find them if you are patient enough.
regards
Mech
Old 10-02-2011, 11:10 AM   #7 (permalink)
...beats walking...
...rule-of-thumb's are:
-1 psi per month
-1 psi per -10ºF
Old 10-02-2011, 12:06 PM   #8 (permalink)
nemo's Avatar
Chief - '06 Grand Prix Base
90 day: 24.38 mpg (US)
Not Mine - '012 Fiesta S
regards
Mech
Adding a little soap can make it even easier.
There are no answers. Only more questions.
