Old 05-07-2009, 04:27 PM   #21 (permalink)
Vekke's Avatar
Siitin - '98 Cordoba Vario
90 day: 58.56 mpg (US)
Starppa - '96 Starlet
90 day: 35.06 mpg (US)
Aeroscania - '97 P94D 260
90 day: 9.35 mpg (US)
VW Lupo 3L --> 2L - '00 Lupo 3L
Diesel
90 day: 64.74 mpg (US)
Mods done after last post:
Oils changed to Valvoline Syn power III 5w-30
Transmission oils Mobil 1 VS200
Cat remove
Other side mirror done
New tires Toyo 350 170/80/R14, 60mph is now 1950 rpms
Towing bar remove and other minor weight savings.
Consumption is going to right direction.
Future (next) mods will be:
-13" aluminium wheels and tires in size 165/70/R13 to the rear
-Lighther hubcaps
-New front bumber
-glassfibre hood
-Better and stronger kammback. Last one wasnt enough good looking for my girlfriends taste...
-weightsavings etc
Old 05-08-2009, 01:08 PM   #22 (permalink)
Bio Deezler - '03 Jetta GLS TDI
90 day: 50.78 mpg (US)
Vekke, everything sounds great.
.... except the CAT removal! Why why why. Environmental cost is not worth the 2 mpg!
Old 05-09-2009, 03:51 PM   #23 (permalink)
AJI
Panda - '08 Panda 100HP
90 day: 34.89 mpg (US)
Agreed. It's interesting seeing something a little different from the usual Civics etc... but I like to think that reducing fuel consumption goes hand in hand with reducing environmental impact, so gaining only small increases in fuel efficiency at the cost of the car being cleaner isn't a path I'm too keen on...
Old 05-10-2009, 05:37 PM   #24 (permalink)
Vekke's Avatar
Diesel
Is a old clogged catalysator a planet saver? If the diesel starts to be 10 years old the catalysator is not in the best shape it could be. Mine was just clogged but it could be already broken so that the metal mesh is stopping the gases to go by. This happens usually if you have hit the catalysator to something or it starts be old and badly worn out. So my decision was to take it off.
Old 06-30-2009, 02:32 AM   #25 (permalink)
Vekke's Avatar
Diesel
MPG reading is coming up!.
- Lighter aluminium wheels are in place in front and in back of the car.
- Lighter glassfibre hubcaps are in place. Attached by zipties .
- Tinted my windows
- Installed lowering springs
Best tank so far is my last tank.
2009-06-29 843.8 mi. 11.81 US gal MPG71.45 US
100% trip. avg speed 84 km/h. Could ave hit 3l/100km mark but rushed 80 km at speed of 77 mph. That rose my tank consumtion from 3.0 to 3.2! So keep steady max speed limit if you want good looking mpg figures. I could have hit easily 1000 miles but filled up in my usual station.
- Installed lowering springs in the midle of the tank.
Results:
- best coastdown test end speed 77km/h (+1km/h).
- best 75km "test leg" consumption from 2.7 l/100 km to 2.6l. Also that route average speed was highest of so far 80 km/h. So I see best mpg figures with higher speeds .
Next mods:
- install my almost ready glasfibre hood. ~6kg +aero effect on wipers
- new more tear drop shaped front bumber with wire controlled grill block ~3kg
- flat undertray
- Side skirts
- more weigth savings
Next target:
Try to keep the tank consumtion under 3.5l/100km.
Old 07-31-2009, 11:13 AM   #26 (permalink)
X-Frenchy: very
groar's Avatar
scenic - '01 scenic
90 day: 43.09 mpg (US)
megane - '97 megane classic
Diesel
90 day: 72.53 mpg (US)
dennisius - '06 Prius
90 day: 55.12 mpg (US)
Congrats
Current tank is the good one
Denis.
Save money & CO2 at home : http://ecorenovator.org/
Created and managed by the creators of http://ecomodder.com/
Earth and health are priceless, so are kilotank and AT-PZEV
Best Mégane tank: 1268.9mi @ 77.847 MPG(US)
2008/06-2011/10 saving:
  • 5725.5 kg CO2 (5342.6+382.9)
  • Diesel / Money: 42.17% = 2446.25€ = 3357.26$
megane : thread - kill switch.
Old 08-01-2009, 04:20 AM   #27 (permalink)
Vekke's Avatar
Diesel
Made a miscalculation in the miles to gallons translation and tank was 5.8 miles short of 1000 miles :/. However longest tank so far, but I had my brother in the car and he didn't like the run out of fuel idea so I had to fill up at 1600 kilometers mark. SG showed 75 more kilometers left and needle weren't even close to empty. 180 km:s light on were enough for my brother.
Old 08-01-2009, 01:30 PM   #28 (permalink)
Chug - '96 Polo CL
90 day: 49.42 mpg (US)
Loving the Cordoba action - same dash as my polo!!! , where did you get the straight pipe for the rear box delete??
God I want a VAG PD again!!!
good things come to those who wait, sh*t turns up pretty much instantly
twitter.com/bertchalmers
Old 08-01-2009, 02:01 PM   #29 (permalink)
Moderator
tasdrouille's Avatar
The Guzzler - '08 Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '011 Soul 2U
The 98 Cordoba was a PD? I thought it had a rotary pump. What advantages do PD engine have? They often get early cam wear.
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 08-01-2009, 02:12 PM   #30 (permalink)
Vekke's Avatar
Diesel
98 polo is basically the same car as the cordoba... Exhaust pipe is self made/welded. Now I get 3.3 litres/100km consumtion if I drive speeds under 110 km/h.
Rob in petrol car the exhaust noise will rise much more than in diesel if you delete your rear muffler. The turbo works as a muffler and reduces the exhaust noises pretty much.
What comes to the cams, they dont wear if you use right oil and change it regularly :/.
At the moment I am disapointed that I havent got any time to do mods in my car at last one and a half month. Next week I will try to finish my glassfibre hood.
Starting My A/C Seat project dremd General Efficiency Discussion 80 07-09-2010 03:20 PM
EG seat swap Del Sol n2 EG Civic Nden DIY / How-to 6 04-02-2010 03:30 AM
Cheap man's AC! (beaded seat cover) swoody For Sale 1 09-17-2008 05:15 PM
Do Metros have back seat belts & do child seats need to be installed on a seat Wayneburg General Efficiency Discussion 8 05-07-2008 02:11 PM
