Old 09-25-2009, 01:30 AM   #1 (permalink)
JJMunoz's Avatar
Seriously? - '94 Civic DX
90 day: 55.57 mpg (US)
Seriously! My 1994 Honda Civic DX Build Thread!
This is my build thread for my 1994 Honda Civic DX Coupe!
Bought in May of 2009 with the idea of hypermiling in mind.
I got involved in a motorcycle accident that month and I wanted something that got just as many mpg's as the bike did which was around 55.
However, I got 63mpg once out of the bike!
So I've yet to reach my previous goal.
I want more mpg than that now though.
So I've got my work set out for me.
Anyway, let me know what you think!
The car!
Front shot of the car with the caulk drying
Lulz
Mirror deletion and caulking around the little holes left by the deletion
New interior mirrors installed
Coroplast ramp for air diversion from wheel wells
Side shot of the ramp
Caulk drying around the headlight. Once it dries it will become clear!
Current engine bay
Hole in the engine bay where everything used to be!
Old 09-25-2009, 02:34 AM   #2 (permalink)
Cd
no
Cd's Avatar
Looking good !
Did you smooth out the caulk ? It may not matter much to the air, but it takes only seconds to do.
( No sense in having the car look like crap right ?! )
I still don't get the concept of the wheel ramps, since it diverts the air right smack into the tire and the pavement. It seems like it would be more beneficial to make them split the air around the tire.
What all have you removed from the engine so far ? ( I see no A/C )
Also, what is your baseline MPG at the start of the project, and in it's current state ? Edit - nevermind
http://ecomodder.com/forum/em-fuel-l...vehicleid=2711
Old 09-25-2009, 03:35 AM   #3 (permalink)
Moderate your Moderation.
Cara - '00 Caravan Base
90 day: 28.45 mpg (US)
Nice job so far! Welcome to EM, and happy motoring!
(SRSLY...)
Originally Posted by tasdrouille View Post
Because bean counters always win, that's why.
Old 09-25-2009, 03:39 AM   #4 (permalink)
pgfpro's Avatar
dturbosol - '93 del sol s
90 day: 66.07 mpg (US)
worktruck - '01 Sierra 1500 SLE
90 day: 16.17 mpg (US)
Nice ride!!!
How do you like your mirror mod? I need to do something along these lines.
Old 09-26-2009, 12:29 AM   #5 (permalink)
JJMunoz's Avatar
Turtle
Originally Posted by Cd View Post
Looking good !
I did smooth out the caulk. The caulk near the hood in the center's a little lumpy, but when the hood closes and the weathersealing hits it, it shouldnt even show.
And as far as I can see, ramps are better than no ramps. With a ramp, the air is diverted towards the ground, and the airflow would be more likely to hit and end there, whereas with no ramp, the air goes into the wheel well and swirls, causing drag.
I don't know a lot about aerodynamic efficiencies, but that would make the most sense to me at a glance.
I also noticed basjoos did it, and he's attained over 90 mpg in the past sooo..I think I'll trust his judgment too!
Old 09-26-2009, 12:32 AM   #6 (permalink)
JJMunoz's Avatar
Originally Posted by pgfpro View Post
Nice ride!!!
Thanks! I initially noticed at least a couple miles per hour more on coastdowns from 65 mph after I turned the key back on with the mirror removal.
The interior mirrors aren't too great. I find myself looking over my shoulder often, but I also have a 300mm wide broadway mirror which helps. Most times driving at night, all I need to see is light in the mirror to know someone's next to me.
So, all in all, they're not that bad. I'd say it's worth it!
Old 09-26-2009, 12:46 AM   #7 (permalink)
Cd
no
Cd's Avatar
Looking forward to seeing some pictures of the belly pan.
What's next ?
Since this is a new thread, can you remind us all of what you intend to do to the car mod wise ? ( Add smooth wheel covers, delete mirrors ...etc. )
Old 09-26-2009, 07:38 AM   #8 (permalink)
basjoos's Avatar
Aerocivic - '92 Civic CX
90 day: 71.28 mpg (US)
AerocivicLB - '92 Civic CX
90 day: 75.46 mpg (US)
[B]
A vertical divider that would split the air around either side of the front tire is more efficient than a ramp and is what I would preferred to have installed. But it would be more easily damaged by impact with hard crusted snow, small furry animals, and high curbs encountered while driving that the ramp can tolerate without damage. Its one of those theoretical meets reality sort of things. The Loremo and Daihatsu UFE-III both use a vertical air splitter and it will be interesting to see how well the one on the Loremo stands up to the real world before getting nicked and broken off. Perhaps if you built the thing out of thick steel and had it bolted onto the car's frame it would hold up, but as a coroplast structure bolted onto the car's plastic bumper, it certainly wouldn't.
aerocivic.com
Old 09-26-2009, 10:03 AM   #9 (permalink)
Moderator
Daox's Paseo - '97 Paseo
90 day: 67.16 mpg (US)
Daox's Prius - '04 Prius
90 day: 52.66 mpg (US)
Nice work so far!
EcoRenovator.org - Efficient living and green home improvement
Prius Build Thread
Paseo Build Thread
Old 10-02-2009, 01:17 AM   #10 (permalink)
JJMunoz's Avatar
More pics taken today! And I got the front bumper constructed today as well!
The underbody paneling!
Nice tight fit of underbody paneling by the muffler!
Other rear underbody paneling.
Another shot of the underbody paneling near the exhaust.
Part of the box I constructed to divert airflow from the new bumper portion through old ABS plastic piece I had on the front bumper.
The box almost installed in the front bumper!
The box installed. Front view.
Another view of the box.
The almost finished product of the front bumper! We can definitely see an idea copied from Basjoos here. haha My radiator airflow slot is somewhat different though, passing directly through the bumper, still.
As usual, let me know what you think!!
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 130 10-29-2009 11:11 PM
Converting Cali Civic VX to Fed (lean burn) VX NachtRitter DIY / How-to 1 03-01-2009 06:31 PM
For Trade: 1994 Honda Civic VX in North GTA flydude1221 For Sale 1 02-05-2009 04:59 PM
Official 2001-2006 Honda Civic EcoMod/Mod Thread FEET_ EcoModding Central 0 05-12-2008 02:11 PM
'93 Honda Civic DX Coupe -- Good Project Car? RH77 The Lounge 5 04-01-2008 10:25 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.3.2
