Old 03-08-2010, 10:20 PM   #11 (permalink)
epic stock master
luvit's Avatar
86 Accord LX (carb) - '86 Accord LX
90 day: 35.57 mpg (US)
imagonna try this. you type'd sumtin i may actually 'njoy, fer once. tanks.
single person car thread
Old 03-08-2010, 11:29 PM   #12 (permalink)
chop suey
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
I can't tell you how much that means to me.
Old 03-09-2010, 01:36 AM   #13 (permalink)
93 Metro Streamliner
AeroMetro - '93 Metro
Two more solutions to belt squeal.
Even if the tensioner pulley spins well, a worn out hinge in the tensioner itself can cause the tensioner to run crooked, which causes the belt to run off-center and at a slight angle.
Goodyear Gatorback belts are worth the extra money. Caravans are famous for belt squeal. I changed the old belt and all the pulleys and tensioner, and still had squeal. Spent the extra coin for a Gatorback belt and it's totally quiet now.
Old 03-09-2010, 01:40 AM   #14 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Caravan V6 squeal is usually because of mis-alignment of the accessories, which happens over time due to vibrations.
The actual fix is to adjust the alignment of the accessories which are out of alignment by adding shims.
I'd like to think that people might open their eyes at some point... instead, I find it more and more likely that I'll just close mine.
-- Author kept secret.
Je ne veux pas d'une meilleure vie. Je veux être heureux avec celle que j'ai maintenant.
(I do not want a better life. I want to be happy with the one I have now.)
Old 03-09-2010, 01:26 PM   #15 (permalink)
The main problem was misalignment of the tensioner, which was running crooked so the belt was running on the edge of the pulley. Solved with a new tensioner.
Why take everything apart and add shims when spending an extra $10 for the premium belt achieved the same result?
Old 03-09-2010, 09:22 PM   #16 (permalink)
Spending an extra $10 doesn't always achieve the same result. You got lucky, while thousands of other Caravan owners got ripped off with no service recall to cover the issues, even after the belts literally will jump right off the accessories, often ending in a stranded vehicle because of loss of power due to very quick battery drain.
Old 03-23-2010, 09:49 AM   #17 (permalink)
debbott
Have any of you tried pure silicone spray? It should work as well, if not better than armor-all.
Another thought would be baby oil, there is nothing more pure and it would keep the belt soft and supple. Debbott
Old 03-23-2010, 02:49 PM   #18 (permalink)
chop suey
Blue - '93 Tempo
F150 - '94 F150 XLT
My thought is, lube of any sort has no place in a belt that is expected to transfer power.
JethroBodine (04-09-2011)
Old 03-23-2010, 03:12 PM   #19 (permalink)
JasonG's Avatar
1 Ton - '94 C3500
90 day: 19.26 mpg (US)
Big White Brick - '03 Express Van
90 day: 15.19 mpg (US)
And petroleum byproducts degrade rubber as well.
Roughing the belt works well, I never thought of roughing the pulley, sounds like a plan.
Support Bennelson !
I can't understand why my MPG's are so low..........
16000lb, 41' Toy Haulers are rough on FE!
Old 04-04-2011, 11:22 PM   #20 (permalink)
chop suey
Blue - '93 Tempo
F150 - '94 F150 XLT
Found more info on serpentine belt noises and cures... if the Gates guys don't know, then nobody knows...
Troubleshooting V-ribbed Belt Noise - Gates Belts
Tensioners too:
http://www.gates.com/brochure.cfm?br...ocation_id=544
P.S. The belts I wrote about are still quiet.
Car went belt commando today... prelim. +10%FE gascort Success Stories 18 01-22-2012 12:02 AM
Serpentine Belt Noise mhmitszach Off-Topic Tech 3 06-20-2009 12:38 AM
Removed '00 Civic power steering belt and got good results but... hondaworkshop EcoModding Central 8 10-07-2008 02:23 PM
Good take on things (long) Daox General Efficiency Discussion 8 08-30-2008 05:11 PM
How get a shorter belt........ }{ead$hot Zod EcoModding Central 4 04-24-2008 12:13 AM
