07-13-2008, 05:31 PM
"Service engine soon" light on
Driving my 97' Metro home last night and a "service engine soon" light came on. I don't have an owner's manual, wish I could find one. Anyone know what that particular light means? Car seems to be running fine. I've only had it for a few weeks.
07-13-2008, 05:42 PM
Dartmouth 2010
Some vehicles (dunno about the metro) have a light that comes on at certain service intervals (ie, 30k, 60k, 100k). Might be that.
07-13-2008, 05:49 PM
needs more cowbell
Go to autozone or advance or somewhere and get borrow their code reader and then take those codes it spits out over to TeamSwift • Index page .
07-13-2008, 06:01 PM
My odometer reads 154,742. Had the oil changed two weeks ago. I'm worried that this may be the equivalent of a "check engine" light.
07-13-2008, 06:02 PM
Good idea I'll try and get the code checked if that what it is.
07-13-2008, 10:50 PM
Hi-Tech Redneck
Just post what the code is here and I can help you out.
07-13-2008, 11:53 PM
Beta-tested it to death!
If you were planning on getting a Scangauge anyways, now would be a great time.
It will read codes, and you can reset them too.
I saved my wife some trouble the other day by having her read me a code form her car over the phone. Was able to figure out that it was just a loose gas cap!
Handy feature to have!
07-14-2008, 12:21 AM
Pokémoderator
rick390 -
ditto. Autozone does this for free.
CarloSW2
07-14-2008, 01:47 AM
#9 (permalink)
They'll tell you what the code is, and give you a print out in store...
No need to make more work out of it by borrowing (which they probably won't let you) the reader, then coming home and finding the code.
But, often times it's an emissions related problem over most problems. The ECU regularly runs test on the car, and if it fails a test it throws the check engine light. Then it will test the specific problem over and over, and if it passes the test (X) amount of times, it will go out. But, even if things are in check, it can take a week or two of driving to get rid of the trouble code. You can have them clear the codes at a parts store probably, and just see if it comes back on.
Lets see how far it can go
"All I know about music is that not many people ever really hear it. [...] But the man who creates the music is hearing something else, is dealing with the roar rising from the void and imposing order on it as it hits the air. What is evoked in him, then, is of another order, more terrible because it has no words, and triumphant, too, for the same reason. And his triumph, when he triumphs, is ours." -Sonny's Blues
07-14-2008, 06:48 PM
#10 (permalink)
I took it to the local Schuck's auto parts store. They were kind enough to read the code for me. The code was P0420, " catalytic system efficiency below threshold (Bank 1)". So there it is ladies and germs. I guess I need a new cat. Wonder what that feline will set me back.
