Old 08-27-2008, 02:20 PM   #1 (permalink)
Deadly Efficient
Tango Charlie's Avatar
Olivia - '03 Vibe base
90 day: 38.61 mpg (US)
Silver Bullet - '00 Insight
90 day: 60.3 mpg (US)
SG shows 0.04 GPH during EOC
Shouldn't it read 0.0 GPH and 9999 MPG like during DFCO?
Instead I get 0.04 GPH. Which isn't much, but MPG's go to 1K or less, depending on speed, of course.
Does this mean I have a leaking injector?
But if I did, would I still get the maxed readings during DFCO?
-Terry
My Pet Threads:
Vibe Mods and What's in a UserName? and YKYAEI
Old 08-27-2008, 05:01 PM   #2 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
Team Saturn
90 day: 43.05 mpg (US)
Tango Charlie -
(I have an old-school-ugly SGI)
I don't think you have a leaky injector. Even 9999 MPG is technically wrong. My theory is that there is some kind of divide by zero failsafe leading to the 9999 MPG, which should otherwise be infinite.
When I EOC, my MPG is 10 times my MPH. Soooooo, If I am coasting at 45 MPH, the SG reads 450 MPG.
The 0.04 GPH and sub-1K MPG sounds similar to mine. The next time I do an EOC, I will check on my GPH and tell you what it is.
On a similar note, when I EOC, the engine RPM should be reporting 0. However, on my 1999 Saturn SW2, it reports 61 RPM. This leads me to believe that either :
1 - There is "noise" in the RPM sensor.
2 - The ECU/PCM is reporting 61 RPM even though it is "seeing" 0 RPM from the sensor.
CarloSW2
American Solar Energy Society
Old 08-27-2008, 05:24 PM   #3 (permalink)
papa smurf - '81 pickup 4wd dlx long bed 1/2 ton
90 day: 17.6 mpg (US)
Heep - '011 Grand cherokee Larado x 4x4
90 day: 19.92 mpg (US)
Old toy - '81 Cm400e
Da bike - '06 Shadow Vlx deluxe
90 day: 50.18 mpg (US)
it is cause of the % of correction, i have 10.1% correction and see .05 on the sg when eocing, but i am still getting the exact fuel in the tank as it says. if it says 12.2 gallons till full it usually takes 12.2xx gallons
2011 Jeep grandcherokee larado x v6 4x4. (wifes/weekender)
98 taco base 4x4 i4 toyota bought back due to a rust spot. gone but not forgotten.
81 toyota 4wd long bed 1/2 ton
