Old 06-12-2008, 01:52 PM   #1 (permalink)
Legend in my own mind
trikkonceptz's Avatar
Evil Pumpkin - '08 xD RS 1.0 #1633
90 day: 35.45 mpg (US)
Silent Silver Killer - '010 Insight EX
90 day: 51.5 mpg (US)
SGII Driving Lessons
OK finally got my SGII up and running, now come the questions ...
I understand open/closed loop and throttle position. Now how do I use them to my full advantage? Can I accelerate to speed with as high a TP as possible without going open loop and still expect to increase FE. Or is slow steady acceleration the norm for automatics?
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
Old 06-12-2008, 02:03 PM   #2 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
The higher the engine load (LOD) the better. Load is not directly proportional to TPS which is why I like to use it instead of TPS.
Old 06-12-2008, 02:30 PM   #3 (permalink)
Please explain LOD, I am not familiar with that term or how to monitor it.
Old 06-12-2008, 02:49 PM   #4 (permalink)
CM400E - '81 CM400E
Engine load is basically the % of maximum torque you are using at a said rpm.
Old 06-12-2008, 03:09 PM   #5 (permalink)
OK got it ... now how do I use that with my scangauge and to my advantage?
Old 09-30-2010, 05:08 PM   #6 (permalink)
FoMoCo - '010 Focus se
Team Ford
90 day: 31.34 mpg (US)
How can the LOD gauge (if not, then what gauge?) tell you when your engine begins fuel enrichment, or when it goes out of closed loop?
Old 10-05-2010, 04:31 PM   #7 (permalink)
Absent without leave.
Arragonis's Avatar
George - '011 Aygo Go!
Team m8
90 day: 54.54 mpg (US)
Mildred - '011 Prius T-Spirit
90 day: 45.97 mpg (US)
Genuine question and not having a go, but how does it know what the maximum available torque is, and how does it know what torque you are using when modern cars have such different torque curves ?
Example - Honda Civic Type R (headline 192hp hatchback) has max torque at 5600 rpm (only 142 lb/ft - ), mine has it at 1900 (229 lb/ft ) or around 290+ lb/ft chipped .
I'm intrigued by the LOD measure. I'm tempted to use it but it remains a mystery. I know there is wisdom there, somewhere.
No longer here. Bye, and good luck to all.
Old 10-05-2010, 04:44 PM   #8 (permalink)
CM400E - '81 CM400E
Allow me to answer your question with a question. How does an engine know how much fuel to inject? It calculates it based off the amount of air flowing into the engine. It knows the maximum amount of air it can let in (for the most part, there is compensation for air density etc so LOD isn't 100% exact), and it knows the minimum amount of air. Calculating percentage is a small step away then.
Old 10-06-2010, 01:39 AM   #9 (permalink)
euromodder's Avatar
Hägar - '05 V50 1.6L Diesel
Diesel
90 day: 52.05 mpg (US)
Snert - '06 S40 1.6L Diesel
90 day: 58.06 mpg (US)
It's one of my permanent gauges, and it does give a good indication of how hard the engine is working.
Yesterday however, it was jumping from 30 to 55 while I was doing 100kph on the motorway @ 67+ mpg (HM would see a lofty 81 mpg).
Lifetime fuel consumption :
Old 10-06-2010, 02:59 AM   #10 (permalink)
Arragonis's Avatar
Team m8
On my Diesel it will be a lookup value in a table based on factors like engine speed, temp, throttle position and air flow. But I still wonder how it knows what the max is to work out how much of it you are using.
To amplify a little. To work out % torque you would need to know for the current engine speed how much torque your engine can make at max, and then how much you are making now.
Or is it just fuel load, how much fuel is being added compared to how much could be added ?
lod, scangauge
Teaching Efficient Driving in School 93DelSol Hypermiling / EcoDriver's Ed 17 06-05-2010 09:49 PM
Any advice for driving by vacuum guage? video Chris D. Instrumentation 33 02-21-2009 11:54 PM
Driving Log Book bennelson EcoModding Central 13 10-04-2008 07:39 PM
SGII Not quite right dremd Instrumentation 37 09-26-2008 12:33 PM
SGII Read out trikkonceptz Instrumentation 1 05-16-2008 05:25 PM
