Old 02-25-2009, 11:28 PM   #1 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Zombie Insight - '00 Insight MT
90 day: 62.82 mpg (US)
SGII Horsepower gauge & related gauges
I followed the instructions in the manual for creating a Horsepower gauge in my 1996 Subaru Legacy. The output of said gauge is about 30% higher than what would be plausible. It was showing something like 30BHP cruising around at 49mph. At redline and 80% throttle, it was showing 165BHP, while my engine is only rated for 135.
So, how does the SG calculate HP? It's obviously doing it wrong. Can I get it to multiply by a constant calibration factor?
Also, if a working HP gauge could be made, you'd probably want a few related gauges:
BSFC gauge = BHP/GPH, showing how many milligrams of fuel per second it takes you to make a horsepower.
Torque gauge = BHP/RPM, because that would be cool.
Old 03-02-2009, 08:08 PM   #2 (permalink)
Left Lane Ecodriver
Or does anyone at least know how (or whether) I can take Gauge X and divide by Gauge Y and display the output as Gauge Z?
Old 03-02-2009, 09:43 PM   #3 (permalink)
Check the coding manual ScanGaugeII - Add-A-Gauge
Old 03-03-2009, 09:20 AM   #4 (permalink)
Left Lane Ecodriver
Ah, so I see the answer is no, that can't be done.
The MTH field doesn't let you multiply or divide by a gauge or a data stream, just by a constant. Although the stock mpg and cpm gauges involve division of one data stream by another, I don't see any way to add such gauges to the SGII, so I suppose the BSFC gauge is never going to happen. :-(
I see the stock Horsepower gauge has a multiplication by 4.35 built in. I could correct this value to make it accurate at at least one point on the torque vs. RPM curve, but I don't know what method the SG uses to calculate HP, and I'm skeptical about its accuracy.
Mullet's Metro Project Johnny Mullet EcoModding Central 302 02-06-2011 07:04 PM
10-minute Accord vacuum gauge "install" Clev DIY / How-to 7 09-10-2010 03:53 AM
Econometer/Vacuum Gauge Installation Guide Johnny Mullet Instrumentation 76 07-29-2010 08:52 PM
Stock Temperature Gauges jcantara Instrumentation 24 05-26-2010 11:26 PM
Vacuum gauge problems :( DifferentPointofView Instrumentation 3 05-14-2008 11:04 PM
