Old 05-05-2008, 04:38 AM   #1 (permalink)
EcoModding Minded
Chris D.'s Avatar
Lunar Mist - '02 Tacoma SR5
90 day: 25.31 mpg (US)
Silver Streak - '08 Corolla S
90 day: 38.25 mpg (US)
Send a message via AIM to Chris D.
SGII + ICE OFF = .003 cpm?
Can anyone explain to me how ICE off is causing my SGII to read .003 CPM?
Shouldn't that be zero?
Old 05-05-2008, 06:49 AM   #2 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
There is a fuel cutoff setting somewhere in the setup menu. If your gauge doens't go to 9999 mpg with EOC you need to look at playing with that setting.
Old 05-05-2008, 09:37 PM   #3 (permalink)
EcoModding Minded
Chris D.'s Avatar
would you have any idea which way I need to adjust it from my prior position?
does this mean all of my other readings are way off if this is reading like that?
Old 05-06-2008, 07:56 AM   #4 (permalink)
CM400E - '81 CM400E
Adjust the value down. The advice I've gotten from others is make sure your car is warmed up with no accessories no and then see what the GPH (gallons per hour) are at idle. Set your cutoff just below that value and you should be good.
Old 05-09-2008, 12:25 AM   #5 (permalink)
I REFUSE!
thebrad's Avatar
VTEC Express - '96 Civic CX
90 day: 57.72 mpg (US)
Send a message via AIM to thebrad
MASTER!
MASTER!
Old 05-09-2008, 01:45 AM   #6 (permalink)
EcoModding Minded
Chris D.'s Avatar
I cant get this calibrated for nuttin here..
any locals wanna school me?
no matter which way I adjust it I always
have something as a cpm with ice off..
defective SGII? defective owner?
Old 05-09-2008, 02:00 AM   #7 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
Team Saturn
90 day: 43.05 mpg (US)
thebrad -
Originally Posted by thebrad View Post
MASTER!
MASTER!
Shake?
CarloSW2
American Solar Energy Society
SGII Not quite right dremd Instrumentation 37 09-26-2008 12:33 PM
Random thought reguarding ICE off/MPG figures Chris D. EcoModding Central 8 04-28-2008 10:25 AM
