Old 01-22-2012, 04:19 PM   #21 (permalink)
Vulcan - '05 Vulcan 500 LTD
90 day: 60.08 mpg (US)
Mag Pearl - '011 Fiesta SE Hatch
90 day: 45.91 mpg (US)
I wonder if 90% load works out to about the same percentage of atmospheric pressure reading on a vacuum gauge. Highest regards to you Sentra for the dedication to precision in measuring the optimal P&G load levels. It convinces me that I am probably not accelerating quite aggressively enough.
regards
Mech
Old 01-22-2012, 04:30 PM   #22 (permalink)
I also wonder at what point in load you hit WOT enrichment, since the MPG is increasing significantly as the load increases? Could you improve the MPG by pushing it to 95% load?
regards
Mech
Old 01-22-2012, 06:55 PM   #23 (permalink)
Pishtaco
SentraSE-R's Avatar
Clean Green Toaster Machine - '06 xB
90 day: 45.81 mpg (US)
IIRC, 98% and 99% engine load acceleration still stayed in closed loop. I did test a 95% load pulse later. It used slightly more fuel, but didn't shorten acceleration time or distance.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
Mean Green Toaster Machine
49.4 mpg avg over 30,375 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
45.8 mpg over 2235 miles, 164% of '08 EPA
The Following User Says Thank You to SentraSE-R For This Useful Post:
Old Mechanic (01-22-2012)
Old 01-23-2012, 06:57 AM   #24 (permalink)
fastegg's Avatar
Too many other distrations
Originally Posted by SentraSE-R View Post
It doesn't matter for my tests, since I used the same stretch of road going the same direction, on the same day. And while we know the engine load will be higher, and pulse times will be longer on an incline (and load will be lower/pulse times shorter on a decline), there's no reason to expect the relative fuel consumption at each load to differ.
Yes, fastegg. I think it's ground breaking, too. I guess it's too technical, or too much work, or too expensive. I'm somewhat disappointed in the lack of interest/lack of comments returned on such breakthrough knowledge.
Yeah me too.. I mean literaly every day there's another device that makes my job easier... As i said, i built and road raced motorcycles for 25 years and all our tuning was guesstimates, 1,000's of plug chops, seat of your pants asking someone else or luck.... or hope !!!!
Now we have a choice of SG2, UG, DashDyno, OT-2, ScanXL Pro, Superchips (flash tuners), and another one i found today the 'inTune' touch screen tuning device. (check out this site, tunertools.com its got heaps of new tech) and about a dozen other sites.. and i find it just so bloody fascinating and happy that there are guys out there, all over the world sitting down working out how to make this stuff work, make it cheap, make it compatible with my car (and everyone elses), make it easy to use, make it realiable... and updatable... all that !!!!!! I reckon its f**ken unreal !!!
The only problem ive got now is deciding which one to get. I like the DashDyno, as it works out HP and torque, its got a GPS for gods sake to calculate the terain your driving on and accurate speedo, ports for O2 sensors and EGT... (go and have a look at its key features at the Autarra site
auterraweb.com/dashdyno.html ... Right now what i really want is super fine fuel consumtion figures... I need a tool that can tell me if i change tire pressures it can tell me, and by how much..... even only a few short years ago, a device that could do this was not even dreamt up yet, and yet here we are, the UG and SG2 might and how cheap are they ??? ... ... ... ... puts a big smile on my face...
I hope i'm not writing too much ?.... A few months back i bought an Autel MS509 code reader/scanner thingy... $70 'cause my girlfriends Peugeot 307 had a DTC light on... its been on for years, weve been charged $75 twice during servicing to turn the light off but it kept coming on so i bought a cheap scanner so I could turn the light off...and it said 'vehicle speed sensor' fault... there is a speed sensor on each wheel but it wouldnt tell me which one, the local Peugeot dealer wouldn't tell me how to check it.... they wouldn't help me one iota...
they just said "bring it in and we'll work on it" GRRRRRRRR (( so i'll leave the light on.. its not effecting anything.... Now, an unexpected find was on live view it tells me i can only get TP 85% max...(throttle position will only get to 85%...its fly-by-wire so, i wouldn't know what to look at... this would explain why its sooooo slow on hills.... I walked down to my friendly local Peugeot dealer and asked if they'd come accross this and all i recieved was the backs of their heads.... GRRRRRR (( Now to put that in perspective, ive rung my local Lexus dealer services dept and they couldn't be helpfull enough... They faxed me pages out of the workshop manual.... talked at length about servicing issues and i asked them if they'd have any idea if i could fit paddle shifters.. He said "leave it with me"... 2 days later he rang me back, he had asked some Lexus electrical guru and told me "no problem" blah-blah-blah... faxed me electrical pages out of the Lexus book with surgestions about the several ways to go about it.... "If you have anything you think we could help you with, call us" Its the black and white difference between 2 cultures....
I'd better stop writing.... i can't remember why i started !
Old 01-23-2012, 08:06 AM   #25 (permalink)
2004 CTD - '04 RAM 2500 SLT
90 day: 21.37 mpg (US)
I'd read it when you posted it, so forgive my not hitting the thanks button then. I was waiting to buy one of these gauges so as to have some references for the thread in order to comment. You're right about cheap and available, it is surprising to be around it all. I'm less than ten years removed from my last car with points ignition (and the first with a computer aboard).
2004.0 7,360-lb DODGE Ram QC/LB 2500 2WD/6-speed Cummins 305/555 ISB. Stock, except LEER bed topper and twin muffler exhaust. 180,000 miles at 4,625-hrs @ 39 mph. 15-cpm solo, 25-cpm towing. (22-mpg avg past 37k)
Fuel Log
Old 01-23-2012, 08:30 AM   #26 (permalink)
sendler's Avatar
Honda CBR250R FI Single - '011 CBR250R
90 day: 92.93 mpg (US)
Ninja 250R SE Green - '09 Ninja 250R SE
90 day: 65.9 mpg (US)
2001 Honda Insight stick - '01 Insight manual
90 day: 60.68 mpg (US)
2009 Honda Fit auto - '09 Fit Auto
90 day: 32.56 mpg (US)
Kawi Ninja650 - '07 Ninja650
90 day: 65.5 mpg (US)
Great data. Thanks.
