Old 03-31-2009, 11:14 AM   #1 (permalink)
SGII Trip computer question
I would like to get a SGII mainly for the trip meter functions. I want to use the average speed function in Time,Speed,Distance rallys.
I have some questions on the average speed function, I don't want to buy one if if won't do what I need it to.
How easy is it to reset? In a rally you will need to be able to quickly reset the average speed many times.
Does it keep computing the average speed when you are stopped? My GPS just quits updating the average speed when you stop, which is no good for rallying.
How fast does it update the average speed? I would like it to update about once a second.
How accurate is it? I would like it to read average speed to the tenth of a mile an hour.
Old 03-31-2009, 12:03 PM   #2 (permalink)
Matt Herring's Avatar
Bone's 2010 Prius - '010 Prius Black
90 day: 56.78 mpg (US)
When you say "quickly reset" the trip meter are you talking 2 seconds or within a minute? Also, are you trying to reset the trip meter while moving or is it a rally that has checkpoints where the car is stopped for a short period of time?
The SGII would keep computing the average speed while you are stopped as it is taking all activity into account from the time the car is started until the ignition is shut off.
The SGII updates with about a 1-2 second lag (as I see my real time mpg update about a second or two after I release or press my gas pedal...its pretty quick just not exactly real-time mpg and avg. speed).
Your best bet would be to either find a friend that has a SGII and try it in your car or purchase one to test it before the rally (you can send it back if it doesn't work out for you).
Old 03-31-2009, 12:52 PM   #3 (permalink)
Moderator
tasdrouille's Avatar
The Guzzler - '08 Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '011 Soul 2U
You just press a single button in the current trip screen, it's that easy.
I believe the time you spend with the wheel not rotating does no count. I can't say for sure though, I'll test it when I get home tonight.
That's about the speed it updates.
The standard average speed gauge is rounded at the mph. However, it is possible to set up a trip xgauge for speed that could average to 2 decimals.
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 04-01-2009, 07:10 AM   #4 (permalink)
Moderator
Just verified this last night. Yes it does. As long as the engine is running, your average speed includes time when you're stopped.
Old 04-01-2009, 10:45 AM   #5 (permalink)
Thanks for the information. It looks like I will order one and try it out.
Another question.
In a rally you are given a odometer check stage. That means to make it fair for everyone, the exact mileage for the first stage is given to you so you can correct your instruments to match the rally masters.
So is there a way, for example, if I find the SGII trip millage is different that the rally masters millage, that I could correct it in the SGII? If so that would be great, otherwise I would just manually correct for it.
Old 04-02-2009, 09:08 AM   #6 (permalink)
Hypermiler
brucepick's Avatar
Lean Burn Civic - '97 Civic HX
90 day: 51.96 mpg (US)
Yes, it has a correction adjustment for speed/distance. It's on pg. 17 of the manual. Follow Menu > More > Setup > Speed.
You can increase/decrease the speed/distance in 1 % increments.
I haven't had a need to adjust this correction (I don't do rallys).
Apparently it reads out current speed while you adjust the correction so if you have a GPS running along side, you can get it dead on, within the 1% increment limit.
Otherwise, my understanding is you need to determine the correction you want to apply, then enter it as + or - the % needed. That is, if you're stopped, the speed shown is zero but you can still enter a correction %.
Check your tire pressure - keep it up !!
We've learned that diet has a closer relationship to cancer than we ever thought. Please see this Wikipedia article on The China Study.
Driving Lean Burn '97 Civic HX, lotsa mods by now! '89 Volvo 240 is semi-retired. I did love that car though!
Old 04-02-2009, 10:31 AM   #7 (permalink)
PaleMelanesian's Avatar
PaleCivic - '96 Civic DX Sedan
90 day: 74.33 mpg (US)
Correction: as long as the ignition is turned on, it keeps updating the time and therefore the average mph. Even with the engine off.
- - - - -Best 11-mile commute: 105 mpg
- - - - -Best tank: 88.5 mpg / 1133 miles
Boston, MA to Gettysburg, PA Trip Matt Herring Success Stories 2 09-03-2008 12:57 PM
Question: "Portability" of SGII? MechEngVT Instrumentation 8 08-27-2008 02:08 PM
LOOOONG Trip Tourigjm Hypermiling / EcoDriver's Ed 25 08-20-2008 01:55 PM
First long trip - 49.7mpg from an xB! brickinthewind Introductions 3 06-11-2008 12:02 PM
New garage feature: Trip Log MetroMPG Forum News & Feedback 1 12-31-2007 02:12 PM
