Old 02-16-2011, 10:29 AM   #1 (permalink)
Dart Lite - '76 Dart Dart Lite
90 day: 18.34 mpg (US)
The Teal Truck - '97 Ram 1500 Club Cab / Short Bed / 2wd
90 day: 14.74 mpg (US)
The H Bomb - '93 Accord LX
90 day: 32.21 mpg (US)
SGII, what inputs does it use to compute MPG?
What information does the SGII use to extrapolate the instant MPG and average MPG numbers?
1976 Dart Lite /6 with 3 speed manual
Old 02-16-2011, 04:55 PM   #2 (permalink)
MPG>HP
Little Blue - '09 Focus SE
Team Ford
90 day: 34.41 mpg (US)
It uses the MAF (mass air flow sensor) in the intake and the VSS (for vehicle speed). By knowing how much air goes into the engine it can use a preset A/F ratio to figure out how much fuel is burnt.
Old 02-16-2011, 05:28 PM   #3 (permalink)
PaleMelanesian's Avatar
PaleCivic - '96 Civic DX Sedan
90 day: 74.33 mpg (US)
MAF (air flow) for some cars, MAP (air pressure) and rpm for others like mine.
It also needs the engine size.
It assumes 14.7:1 air-fuel ratio.
- - - - -Best 11-mile commute: 105 mpg
- - - - -Best tank: 88.5 mpg / 1133 miles
Old 02-17-2011, 02:30 AM   #4 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
Team Saturn
90 day: 43.05 mpg (US)
Backtobasics -
This is what I think is going on :
http://ecomodder.com/forum/187883-post20.html
CarloSW2
American Solar Energy Society
Old 02-21-2011, 11:00 AM   #5 (permalink)
My truck is speed density, so no MAF. How does it use MAP and RPM to give FE numbers?
Originally Posted by cfg83 View Post
Backtobasics -
CarloSW2
Regretably, that is too technical for me.
Old 02-21-2011, 11:07 AM   #6 (permalink)
I may be beating a dead horse. SGII asks me for engine size, but this is a hiccup. The truck was 5.2, but I swapped in a 5.9 a while back. EVERYTHING on the truck is still 5.2 based, but the block itself. 5.2 injectors, PCM programming, everything.
I use the SGII for instanteous driving feedback, more than anything. I have just learned about the tank fill up options where I can TUNE it completely to the truck, but I struggle to input the 5.9 when the PCM and injectors don't know it is 5.9 engine.
Old 02-21-2011, 02:54 PM   #7 (permalink)
Use the actual engine size.
Using engine size, rpm, and MAP, the SG can calculate how much oxygen is being pumped through the engine. (piston pumps per minute * cylinder displacement * air density)
Then, assuming it's fuel injected and uses closed-loop O2 sensor feedback, the fuel must be ~1/14.7 of the air volume for a clean burn.
Really, though, calibration doesn't have to be ideal. If you improve your driving technique by 10%, you'll see a 10% improvement at the pump.
Old 02-21-2011, 04:02 PM   #8 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
Backtobasics -
It's too technical for me too. I've read versions of similar algorithms over and over. Everything I did is based on this post :
Calculating MPG from VSS and MAF from OBD2
What I programmed is a lot of trial and error until I saw MPG behavior in the same range as the SG.
CarloSW2
Old 02-21-2011, 04:14 PM   #9 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
Backtobasics -
I think the SG is making a synthetic MAF :
Code:
IMAP = RPM * MAP / IAT
MAF = (IMAP/120)*(Volumetric_Efficiency/100)*(Engine_Displacement)*(MM)/(R)
Where :
- manifold absolute pressure (MAP) is in kPa
- intake air temp (IAT) is in degrees Kelvin
- R is 8.314 J/°K/mole (constant)
- The average molecular mass of air (MM) is 28.97 g/mole (constant)
Note that in the above formula, the Volumetric_Efficiency of the
  (4-cycle!) engine is measured in percent
Note that the Engine_Displacement is in liters.
In my opinion, there is an assumed Volumetric_Efficiency. When you do a fill-up and apply the correction factor, the correction factor modifies the Volumetric_Efficiency for your engine.
CarloSW2
Old 02-24-2011, 08:33 PM   #10 (permalink)
PaleMelanesian's Disciple
hummingbird's Avatar
City - '04 City iDSI EXi
90 day: 47.47 mpg (US)
Hey, one doubt here:
If MGuino MEASURES the injector pulses and integrates them, whereas SGII just 'guesses' about the fuel being used, I would expect MPGuino to be more accurate. Is this conclusion correct?
Also, what is the strategy the in-built FE meters in the new generation cars use? SGII one, or straight computation of fuel a-la MPGuino from the ECU itself?
