Old 12-08-2011, 05:26 PM   #11 (permalink)
euromodder's Avatar
Hägar - '05 V50 1.6L Diesel
Diesel
90 day: 52.27 mpg (US)
Snert - '06 S40 1.6L Diesel
90 day: 58.06 mpg (US)
Originally Posted by pounsfos View Post
wtf, can someone get rid of this guy please,
His posting - and account I'd wager - are gone, but you quoting him is still here.
Use the triangular warning icon on the lower left of the posting to report it to the admins.
Don't quote spam !
Please edit your posting and remove the spam.
Lifetime fuel consumption :
Old 12-08-2011, 06:04 PM   #12 (permalink)
Big Dave's Avatar
The Red Baron - '00 F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Impala SS
90 day: 21.03 mpg (US)
Reducing parasitic load has its virtues, but rather than haggling up an expensive water pump, underdriving makes more sense.
Of course I went at it the other way. With my numerically low gear ratios, my engine speed is down 35% at a given road speed so my water pump (and alternator, and A/C compressor, and power steering pump, etc) turn at a 35% lower RPM, drawing (pump and fan HP goes up with cube of RPM) 72% less parasitic HP loss. I’ve run this way for several years and had no problems with the auxiliary systems.
Reducing engine RPM works wonders for MPG.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Hard Tonneau and Rugged Air Dam
Old 12-08-2011, 09:07 PM   #13 (permalink)
V8 guy
Sub - '84 Suburban C10
Pickups
camaro - '85 Camaro Z28
I found not having the fan not turn at all when its not needed works best.
1984 chevy suburban, custom made 6.5L high compression diesel.
New engine is in and should be good for 29mpg highway.
1985 chevy camaro mostly stock.
