Of course I can't find a pic now but I remember browsing through a Corvette parts catalog back in the early 80's they had a rear wing that had two little indents so you could set your drink down near the outside corners. LOL Wish I could find that picture.
1996 Pontiac Bonneville SE 3.8L V6
I thought that shelf was for downforce, to keep the trunk from opening while driving?
Mildred - '011 Prius T-Spirit 90 day: 45.97 mpg (US)
And of course you have somewhere to do your ironing when you stop.
2011 Toyota Aygo Go!
Disclaimer - Postings from this author may be total rubbish. All figures in Imperial MPG unless specified. Use at own risk. Shake before opening. Store in cool, dry place.
Originally Posted by Gabriel Voisin about FWD
The system has the following merits: 1) It makes it easier to lower the centre of gravity and bring it forward. 2) It will free us from that unbelievable stupidity:a transmission shaft and tunnel between the engine in front of the driver and the driven wheels. 3) Front wheel drive will increase the interior space of the body, reduce the car's weight and diminish the cost price 4)It will annoy 320Touring by just being better .
I like them.They push the body closer to the streamline flow pathway.
The car pictured could also use a shelf mid-way up the backlight and also extending back until it intersected the imaginary streamline flow pathway.Like Ford kinda did with the Sierra concept and Merkur XR4Ti.
They create the locked-vortex that the outer flow skips over as if it were a solid surface.
