Old 12-30-2010, 01:49 PM   #1 (permalink)
EcoLurker
Execut1ve's Avatar
truck - '94 F150 XLT
90 day: 13.15 mpg (US)
civic - '00 Civic EX
90 day: 36.24 mpg (US)
shift points
Hello all,
I have a 2000 Honda Civic 5spd with the 1.6L 4cyl engine. Can anyone give me any info on the best shift points (by mph or rpm) for fuel econ? thanks!
Old 12-30-2010, 02:31 PM   #2 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
Keep rpms below ~2500 most of the time and give it a healthy amount of throttle.
Old 12-30-2010, 08:28 PM   #3 (permalink)
RSX2fast4mpg - '02 RSX Type S
90 day: 37.22 mpg (US)
bubbatrucker - '98 K1500
90 day: 18.1 mpg (US)
I concur for the most part with Daox. There's some trial and error with every engine. My pick up is comfortable shifting at under 2000rpm, my Acura bogs at under 1750, so I usually have to let it get up to at least 2300rpm to 2700rpm before shifting because it has no low end torque. What you want to prevent is lugging the engine at the one extreme or getting into the VTEC performance end of your powerband on the other end. Any time over 3500rpm is just wasted fuel (says a guy with a 7800rpm redline).
Learn to shift early and use a lot of throttle getting up to speed (most engines are most efficient at 55-75% of throttle), then backing off when you reach cruising speed to the lightest throttle position you can use to maintain speed.
Old 12-30-2010, 09:56 PM   #4 (permalink)
starly - '82 starlet DL
90 day: 40.77 mpg (US)
hold up, so to save gas i must floor it more to make my car more efficient when accelerating???
and here i am trying to use 10" of vac for accelerating!!
im going to test this one out next month
Old 12-31-2010, 12:18 AM   #5 (permalink)
I know it's counter to what we all learned, but try it and you'll likely be surprised. Part of it is just where the engine was designed to be most efficient. The other part is the math of accelerating slowly. Which is more efficient, accelerating at 5 gallons per hour for 10 seconds or accelerating at 2.5 gallons per hour for 30-40 seconds? That's why I always keep both gallons per hour and miles per gallon displayed on my ScanGauge. It teaches you things that don't make sense until you do it and see the numbers right before your eyes.
Old 12-31-2010, 02:09 AM   #6 (permalink)
Northern most ecomodder
reddxhatch - '95 Civic DX
90 day: 46.04 mpg (US)
I have a 95 civic with a 1.5l. I typically use around 2000rpm. If going up hill I let it get a little higher, if down hill I shift sooner. Though I have noted when I get on it a little more and let the revs get higher my mileage does not drop by much if any. The biggest gains IMO for driving efficiently are found in how you slow down rather than how you accelerate.
when using high throttle and high gears for accelerating you may find that by backing off the throttle will not reduce the rate of acceleration. By backing off till right when you feel the rate of acceleration drop slightly you will be pretty close to optimum throttle position for acceleration.
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
The Following User Says Thank You to bestclimb For This Useful Post:
johnlvs2run (03-18-2011)
Old 12-31-2010, 08:17 AM   #7 (permalink)
318iS - '95 318iS
Team m8
90 day: 34.36 mpg (US)
Track Slag 535 - '89 535i Sport
Team m8
90 day: 19.12 mpg (US)
328 Shooting Brake - '97 328i Touring SE
Team m8
90 day: 24.32 mpg (US)
Saab 2.0 Low pressure turbo 5sp manual
1st- shift at 2000
2nd- shift at 2000
3rd shift at 2000
4th shift at 2000
5th use up to 2500 (65mph) then neutral for P&G on the motorway.
I find 1/3 pedal gives me good accel, over a short period.
Also I make sure i'm in the highest gear possible for accel- e.g going 35-50 is 5th, 25-35 is 4th
seems to work ok as currently at 117% of UK combined MPG
Old 12-31-2010, 10:37 AM   #8 (permalink)
Pishtaco
SentraSE-R's Avatar
Clean Green Toaster Machine - '06 xB
90 day: 45.81 mpg (US)
I determined what worked best for my cars with trial and error - back to back tests using a Scangauge while varying my acceleration load. I couldn't find Brake Specific Fuel Consumption charts for any of my engines, so ABA testing was the only way to identify what works for me.
If Executive can find a BSFC chart for his engine, that's where he should start. Otherwise, I suggest buying an SG or an Ultragauge, so he won't be flying blind. 85% load works best for both my 2.5 l Nissan engine and my 1.5 l Toyota engine, but it's rapid acceleration on my Nissan, and very mild acceleration with my Scion. I have to use <70% load on my wife's AT Hyundai (2.0 l engine), because any more causes the torque converter to slip, 65% load on the Hyundai is like 85% on the Scion - very mild
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
Mean Green Toaster Machine
49.4 mpg avg over 30,375 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
45.8 mpg over 2235 miles, 164% of '08 EPA
Old 12-31-2010, 11:34 AM   #9 (permalink)
comptiger5000's Avatar
The Beast - '98 Grand Cherokee (ZJ) 5.9 Limited
90 day: 14.58 mpg (US)
I've found that with my auto, it doesn't actually make that much difference. Normally, I let the big V8 shift around 2200 - 2500. Below 2200 the torque converter is too slushy for it to be efficient, and mpg drops. Unless I start pushing it above 3000 or so, I don't notice a difference on the high end.
Call me crazy, but I actually try for mpg with this Jeep:
Typical driving: Back in Rochester for school, driving is 60 - 70% city
Old 12-31-2010, 11:14 PM   #10 (permalink)
Sweetie - '011 Sonata GLS
90 day: 37.06 mpg (US)
HONKR - '94 KLX686
90 day: 59.94 mpg (US)
That was going to be one of my first tests when I get the Scangauge, time vs throttle and such. I had thought that in a flat mile from still that a shorter accel time with a longer cruise time would be more efficient than taking a full mile to get up to speed.
