Old 03-04-2008, 09:35 PM   #31 (permalink)
40 MPH - Achieved!
TomEV's Avatar
Roxy - '76 Citicar
90 day: 140.87 mpg (US)
Excellent point about fresh lead
My daily commute is 10 miles (5 each way) so instead of hauling around an extra 130 pounds of batteries, I went with six 8v (less expensive as well). My SOC doesn't get below 50%, so I should get good battery life. I planned the number of batteries based on the information in the 'battery FAQ'. Time will tell if it works out.
If I had to go 15 or 20 miles a day, it would have been worth getting the extra two batteries so the SOC wouldn't get too low, and I wouldn't worry about an extra mile or two beyond 20 miles for errands.
From the 'battery FAQ' -
If a battery is discharged to 50% every day, it will last about twice as long as if it is cycled to 80% DOD. If cycled only 10% DOD, it will last about 5 times as long as one cycled to 50%. Obviously, there are some practical limitations on this - you don't usually want to have a 5 ton pile of batteries sitting there just to reduce the DOD. The most practical number to use is 50% DOD on a regular basis. This does NOT mean you cannot go to 80% once in a while. It's just that when designing a system when you have some idea of the loads,
you should figure on an average DOD of around 50% for the best storage vs cost factor. Also, there is an upper limit - a battery that is continually cycled 5% or less will usually not last as long as one cycled down 10%.
Old 03-05-2008, 08:27 AM   #32 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 125.37 mpg (US)
U.F.O. - '00 Insight
90 day: 85.75 mpg (US)
How are you measuring SOC? I have yet to get a hydrometer, and I understand that's what's needed to do it right.
Old 03-05-2008, 12:18 PM   #33 (permalink)
40 MPH - Achieved!
TomEV's Avatar
Roxy - '76 Citicar
I measured SOC with a hydrometer for the first few trips I made with the new pack, but haven't measured it within the past four months. Seems these days that I am less worried about reliability, and 'just drive it'. It has proven to be really easy to maintain - I look at the battery water once a month, and make sure the battery cables are tight/not hot at the same time.
Old 06-27-2008, 10:50 PM   #34 (permalink)
Wannabe
WannabeEVer's Avatar
I think there has to be a way to produce some energy while you're driving like Chris said. At least enough to slow the draining of the battery power. There are so many sources you could get energy from: the wind resistance, the spinning tires, maybe even heat from the controller. Why not attach a sprocket or something to one of the back wheels and have it spinning a small generator inside the car? The laws of thermodynamics are just theories...and its not like no ones ever broken a law before. Even on youtube I've seen people who have made magnetic motors that use little energy, if any at all to start.
Last night I lay in bed looking up at the stars in the sky and I thought to myself, where the heck is the ceiling.
Old 07-05-2008, 03:13 PM   #35 (permalink)
I wish there was more design for some type of reverse balanced clutch as a braking mechanism.
1) Put on brakes a little and the BRAKE CLUTCH slowly engages the engine as a generator on the car.
2) Apply more brakes and the BRAKES convert to standard friction brakes and really stop the car.
Old 12-04-2008, 10:26 AM   #36 (permalink)
Just checked into the twin's thread: I don't think he was happy with the performance of his batteries (range), so...
Big news: I ordered lithium batteries from China. They should be in within 2 months. I am hoping to get 25 - 30 mile range once I have the new pack in.
http://electricmetro.blogspot.com/
Expanding, sprayable foam as an aero construction / shaping material MetroMPG Aerodynamics 9 01-12-2008 12:13 AM
