Old 08-08-2008, 07:00 PM   #11 (permalink)
vtec-e's Avatar
De Yaris - '04 yaris T2
90 day: 69.55 mpg (US)
Originally Posted by Xringer View Post
So, should I give the mini-skirt a try?
Should we be getting worried??
ollie
Old 08-08-2008, 10:01 PM   #12 (permalink)
Old Retired R&D Dude
Little Red - '012 Prius c 2 Two
90 day: 26.38 mpg (US)
Transporter - '09 Escape XLS
Hiya,
I think that skirts will function better is they cover as much of the wheel opening as possible. I tried some smaller skirts (because forming a curve in them was not possible) and now I have Coroplast skirts that "connect" the lowest part of the opening, and they are helping a bit more to improve the MPG.
I'm just looking for the easy way out..
If I can figure out a way to get full coverage, I'll do it.
But, if it turns out to be a lot of trouble, I'm pretty sure the shorter skirts
will work better than nothing at all.
Cheers,
Rich
Old 08-09-2008, 05:22 PM   #13 (permalink)
vtec-e's Avatar
The mini skirt might be a good job alright. You could find that most aero gains might be made with a mini skirt. The advantage of a mini would be being able to change a wheel without having to remove the skirt. Which also means the skirt can be made more secure/permanent.
ollie
Old 08-09-2008, 10:11 PM   #14 (permalink)
ollie
I was thinking of making it short, but about 1/2 way down.
That might be too low to change a tire. Flats are so rare anyways
(I never go off-road or drive in industrial parks), I'm not real
worried about flats.
Cheers,
Rich
Old 08-13-2008, 01:30 PM   #15 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
Team Saturn
90 day: 43.05 mpg (US)
Xringer -
Here's the answer from one of the designers :
Short version would likely be that there was a point of dimishing return on the length.
Everything on that car was an issue of weight (each system team received an allocation of weight in grams), aerodynamics, and cost- with the first two very much taking precedent. Folks are right to speculate that for the skirt to have been longer and follow the body of the car, it would have had to curve in, hitting the wheel itself. So to make it longer, it would have had to curve out, increasing the drag and defeating the purpose. Also, the rear wheels were about 7" closer together than the front wheels, giving yet another curve to deal with. At the end of the day, the EV1 was the most aerodynamic production car ever built, with a drag coefficient of .19- when you get that low, squeezing out any more becomes that much more difficult.
Your friend might be interested in reading a fascinating book about the development of the EV1- it's called "The Car that Could", by Michael Schnayerson.
EDIT: Here's the book :
http://www.amazon.com/Car-That-Could.../dp/067942105X
CarloSW2
American Solar Energy Society
Old 08-13-2008, 03:29 PM   #16 (permalink)
jwxr7's Avatar
the metro experience (retired) - '94 metro 4 dr HB
90 day: 66.44 mpg (US)
I went with mini skirts because they were way easier to do on my car and I think I can still get the wheel off with out removing them (I think? I have never tried). I went down as far as I could easily go (maybe 2/3rds). I would have had to do some bulging and curving of the coroplast that it wasn't willing to do at room temperature to make full skirts.
The wheel will drop quite a bit lower when you jack it up too, so that helps expose the lug nuts.
I never did tests on that mod by itself to see how much they help FE, but I have to imagine that it must be better than no skirt.
Best tank= 81.23 mpg on 07-01-2008
Longest range= 791 miles on 9.74 gallons
Old 08-13-2008, 03:34 PM   #17 (permalink)
jwxr7's Avatar
Here's an image of one of my coroplast miniskirts. I wasn't too worried about lugnut access in the beginning, but ended up with plenty of access anyway.
Old 08-13-2008, 05:50 PM   #18 (permalink)
" Folks are right to speculate that for the skirt to have been longer and follow the body of the car, it would have had to curve in, hitting the wheel itself. So to make it longer, it would have had to curve out, increasing the drag and defeating the purpose."
Thanks! That explains it very clearly. Making me lean towards the shorties..
When I told my wife the plan, she gave me that 'look' and said "WHAT?"..
Cheers,
Rich
Old 08-13-2008, 06:01 PM   #19 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
Xringer -
Hee hee hee, I know that look only toooooo well. I'm so lucky she puts up with me, !
CarloSW2
Old 08-13-2008, 06:19 PM   #20 (permalink)
That looks about like what I'm thinking of..
That open area above the tire needs some blockage!!
Cheers,
Rich
DIY: plastic rear wheel skirts (Geo Metro) MetroMPG DIY / How-to 34 01-06-2012 11:40 PM
I got accosted for wheel skirts! lovemysan EcoModding Central 33 10-12-2008 07:12 AM
1989 crx si fender skirts crexcrex Aerodynamics 26 07-18-2008 03:06 AM
Wheel skirts for the aerodynamically minded Daox Aerodynamics 14 01-27-2008 11:23 PM
Found a coastdown hill! Mini comparo: windows vs skirts vs hatchback MetroMPG Aerodynamics 4 11-27-2007 11:40 PM
