Old 07-16-2008, 08:38 PM   #11 (permalink)
Daily Driver - '01 Explorer Sport
90 day: 18.12 mpg (US)
Send a message via Yahoo to Tony Raine
Originally Posted by gascort View Post
I'd argue still that when you have a smaller contact patch, you drive water out from under your wheel faster due to increased pressure on the water. When I switched from 245/45/17 to 315/35/17 tires in my mustang (got bigger wheels for looks and altering the car's stance only - I've never believed in contact patch - friction relationships) I lost rain performance. I can hydroplane all the time now in that car.
I'm sure there is a speed at which the greater pressure just won't matter due to the water's viscosity, but I haven't ever experienced it.
thats the way i've always thought it was. less tire on the road, means more weight in a smaller spot, means more traction. have your wife/girlfriend/random woman on the street, stomp on one of your feet with the heel of a tennis shoe, and the other with a stiletto.
when fourwheeling, i've found a skinnier tire "digs" down to solid ground (if its there ) and a wider tire "floats" on top.
My Intro
Old 07-16-2008, 08:56 PM   #12 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Christine - '98 Metro Base
90 day: 62.59 mpg (US)
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
We had a heavy downpour here a few days ago and it was so bad we were getting flash floods. I was traveling down this road and seen the right half was under water and I had an oncoming vehicle. I thought to myself that I am screwed since I got 44 PSI in my tires, but I splashed right through the deep water at 50 MPH with no problem.
Old 07-16-2008, 09:48 PM   #13 (permalink)
Troy - '94 Galant GS
90 day: 36.63 mpg (US)
Greenie - '94 Metro LSi
90 day: 55.23 mpg (US)
Not-so-Grand Am - '98 Grand AM GT
90 day: 32.04 mpg (US)
Thanks for the story, Daox. This is one of the primary concerns people have expressed to me about inflating your tires to the sidewall maximum.
If only they knew... if only...
Old 07-16-2008, 10:30 PM   #14 (permalink)
Mica Blue - '05 xA RS 2.0
90 day: 48.22 mpg (US)
Josepha - '08 xD
90 day: 30.76 mpg (US)
Hello,
I think that the tire itself has a lot to do with good wet traction and less hydroplaning. I've had tires that hydroplaned badly at 45mph in just a little water, and others that work great at faster speeds and/or in much deeper water. Wide channels that are well shaped to let the water escape, and the right structure in the tread and sidewall also affect it, I'll bet.
Different tires can be wildly different in the rain; no matter what their internal pressure is. So, just because person has no issues with high pressures, doesn't mean that we all will be okay.
Not all rain storms are the same: from motorcycling, I learned to be very wary in the afternoon cloudburst after a hot day -- the water lifts all sorts of oil out of the pavement, and the surface is close to ice.
Old 07-16-2008, 11:07 PM   #15 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 125.37 mpg (US)
U.F.O. - '00 Insight
90 day: 85.75 mpg (US)
Originally Posted by MazdaMatt View Post
Everything in life is an optimazation problem. I don't drive a minivan because I don't need 7 seats. I can't go telling a family of 7 to go buy an econobox. if you air up your tires for psi, you have to drive more carefully, if you do so, you have no loss. You optimize your mileage and lose out on some other aspects. no biggie as long as you know your car's limits.
Well said, Matt. That's it in a nut shell.
Old 07-17-2008, 01:10 AM   #16 (permalink)
Sequential
Concrete's Avatar
The Truck - '00 S10 Extended Cab
90 day: 22.47 mpg (US)
a over-inflation (a bit) is better in almost every way to under-inflation
simple demonstration
Tire Tech Information - Air Pressure vs. Wet Performance
but I do agree with Neil - each tire is different
the autocross guys over-inflate not under-inflate and they certainly would not accept a performance loss.
if you are running 32psi because your door placard tells you and your tire says more, you are probably under inflated and that IS dangerous.
if you run 32psi because your tire side wall says so - you are on the verge of under-inflation the moment it gets cold or you have any kind of leak, and that could be dangerous.
if you are 5 psi over the side wall - that has got to be minimally significant for safety or we would have people killing themselves because of low accuracy tire pressure gages. If you really want to pop a modern tire (with out help of a nail etc.), you have to run it low.
60 psi in a 32 psi tire - well... that is an optimization issue as stated
personal data:
bought truck and started running 55 psi in 44 psi rated tire on an S10
wear pattern improved - handling improved - rolling resistance improved
ride rougher and road noise higher pitched and more noticeable
wet traction was poor before and I have not notice a change - hydroplaning reduced
Concrete
Start where you are - Use what you have - Do what you can.
Old 07-17-2008, 04:03 AM   #17 (permalink)
Miata - '93 Miata
90 day: 34.79 mpg (US)
Everyone on the highway slowed down to around 40-50 mph.
Wait... Aren't you going already going 55mph to save gas? What was your speed drop for your quick braking?
sidenote: WOW you're nearly doubling your Paseo's epa. That's crazy.
Old 07-17-2008, 06:47 AM   #18 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
The road is a 65 mph freeway. I average 60 mph on it normally.
The slow down was actually while we were going around 45 mph and everyone slowed to about 20 mph because the rain suddently REALLY picked up.
Old 07-17-2008, 10:51 AM   #19 (permalink)
PaleMelanesian's Avatar
PaleCivic - '96 Civic DX Sedan
90 day: 74.33 mpg (US)
I also run 60psi, and I've had nothing but good experience in wet weather. In the past, at 35psi, I've been slipping around much more than now.
- - - - -Best 11-mile commute: 105 mpg
- - - - -Best tank: 88.5 mpg / 1133 miles
Old 07-17-2008, 12:04 PM   #20 (permalink)
6 speed Diesel FTW!
The Golf - '02 Golf GLS TDI
Diesel
90 day: 63.94 mpg (US)
Mongoose - '05 E-bike AWD
90 day: 1810.34 mpg (US)
Send a message via AIM to dremd
I did recently notice that my ABS has to work harder (shorter pulses) at 55psi than at 45 psi when on poor surfaces. No testing, just an observation.
6 speed ALH TDI
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 140 11-21-2011 09:13 AM
Proposed braking test: comparing tire pressure @ 50 psi vs 35 brucepick EcoModding Central 55 06-11-2011 08:29 PM
Tire Engineer here - concerned about hyperinflating tires CapriRacer Introductions 48 09-26-2009 09:25 PM
Tire pressure (of winter tires) tasdrouille General Efficiency Discussion 20 08-12-2009 01:38 AM
DIY: tire bands for Air Pressure Sensors larrydag DIY / How-to 10 05-08-2008 01:30 PM
