Old 10-06-2009, 07:04 PM   #11 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Originally Posted by robertwb70 View Post
I remember reading somewhere that smaller bore longer stroke engines are inherently more efficient. It was somehow related to vintage race car motors (old Ferrari and Jag engines were WAY oversqaure). Smaller engines are also generally more efficient so I'm not sure a 300 is a good starting point for any vehicle smaller than a dump truck. I used to drive a Ford dump truck that had a small (for the job) car-type (didn't have replaceable bore sleeves) engine in it and IIRC it was around 300 CID and while it wasn't ideal it did move the 70,000 lb truck down the road at 70 mph everyday.
Best parts source would probably be dodge/ cummins stuff since it's also inline 6 cylinder configuration and there is a pretty good after market developed around them. Might could even use internal parts, I'm not sure but it's definetly worth a look.
On gas engines static CRs range from around 6 to 1 up to around 15 to 1 but if you look at dynamic CRs there is a MUCH smaller range, ie it's the dynamic CR that sets the limit and this is largely dependent on the cam timing I would assume diesel is the same way but to what extent I'm not sure.
I think it would be more fun to find a way to bolt 2 of them together and make a flat 12 boxster out of it
Normally, I'd agree with the size thing... problem is, I don't have anything else readily available (read: free) with an Iron block, heavy duty crank, and decent specs... not to mention multiple copies of something fitting that description.
I guess the 300, for me, is just kind of a "proof of concept" tinker-build.
Also, the 240 is the same engine with a shorter stroke and longer rod combination, IIRC. That would put the next size down to being the 170 and 140 L6, also from Ford.
Remember - Cheaper is part of efficiency. If I have to pay a bunch of money over the course of a tinker build, I'd have to recoup that in the final product. If I spend less money, I can have lower (read: realistic) expectations without being disappointed in the end.
"Ώʞɐǝɹɟ ɐ ǝɹ,noʎ uǝɥʍ 'ʇı ʇ,usı 'ʎlǝuol s,ʇı"
I'd like to think that people might open their eyes at some point... instead, I find it more and more likely that I'll just close mine.
-- Author kept secret.
Je ne veux pas d'une meilleure vie. Je veux κtre heureux avec celle que j'ai maintenant.
(I do not want a better life. I want to be happy with the one I have now.)
Old 10-06-2009, 07:11 PM   #12 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.85 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 28.75 mpg (US)
...the efficiency was from reduced sliding friction due to less sliding surface area of the smaller pistons: stroke is constant but bore is squared and times PI/4...ie: area vs. volume.
• 2011 Chevrolet Cruze LTZ 1.4LT 6A
• 2009 Pontiac Vibe 1.8L/SIDI 4A
• 2004 Pontiac Vibe 1.8L/MFI 4A
• 2003 Ford Focus ZX5 2.0L/Zetec 4A
• 1971 Dodge Charger 318 3A
• 1970½ Plymouth AAR 'Cuda 340/6BBL 4M
• 1968 Dodge Charger 383 3A
• 1967 Plymouth Barracuda Formula S 383 4M
• 1965 Plymouth Barracuda Formula S 273 4M
The Following User Says Thank You to Old Tele man For This Useful Post:
Christ (10-06-2009)
Old 10-06-2009, 08:17 PM   #13 (permalink)
The older 1st generation cummins (89-93) have what is called a VE rotary pump. It is just a rotary injection pump which (relative to the new Common Rails) have a low injection pressure. These would be probably the easiest to time onto a gasoline engine. There's no electronics to fool with. These should inject PLENTY of fuel to way over-do your 300.
The Following User Says Thank You to bbraden For This Useful Post:
Christ (10-06-2009)
Old 10-06-2009, 08:23 PM   #14 (permalink)
That's what I want, a standalone setup with no computer controls, like my 240D engine. They're easier to work with.
Old 10-06-2009, 08:35 PM   #15 (permalink)
It is worthwhile to mention there are a whole basket of factors determining the bore/stroke ratio of any production engine ranging from legal influences (in England there was for many years a "bore tax" where engines were taxed on the bore diameter and in many countries in Europe the tax on engines skyrockets over about 2.7 litres and 15CV) to manufacturing "conveniences" which is a nice way to say they pick from existing components and do a mix and match to get it all to work ; technical theory and details are often shove abruptly to one side.
Pete.
Old 10-06-2009, 08:39 PM   #16 (permalink)
6 speed Diesel FTW!
The Golf - '02 Golf GLS TDI
Diesel
90 day: 63.94 mpg (US)
Mongoose - '05 E-bike AWD
90 day: 1810.34 mpg (US)
Send a message via AIM to dremd
I'm NO EXPERT but I'd "guess" that the ideal rod/ stroke ratio will be different for gas than diesel.
6 speed ALH TDI
Old 10-06-2009, 08:45 PM   #17 (permalink)
6 speed Diesel FTW!
Diesel
Also look at Benz I6 Diesels
Similar pump in my VeeDub; just electronic controls on a VE pump
There is an "M" pump for VW that is full mechanical; not that it matters (4 cylinder) but . . . .
6 speed ALH TDI
Old 10-06-2009, 09:35 PM   #18 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '010 Cobalt XFE
I seem to remember an individual I met claiming he converted his metro motor to diesel, he said the compression ratio was high enough to be left alone so long as it was WARM outside.
My estimate would be follow KISS.
Diesels have come many different ways dimensions strokes and compression ratios.
Leave your motor alone, replace the heads to a bit higher compression than you need which tends to hover in the 14to17-1 area depending on how warm it typically is), deal with the less than ideal bowl by placing the fuel intake/"injector" in a "mini" bowl (aka suido precombustion chamber) you bore out of the head and live with the less than perfectness being happy that it works with minimal work. Of coarse you will have to find some very thick heads to fit your unit.
The main issue is getting fuel into the motor at the right time, the rest is moot so long as the block doesn't overheat in the wrong place and break on you.
Good Luck
Old 10-06-2009, 09:58 PM   #19 (permalink)
R/S ratio has more to do with piston speed and engine wear than anything else. The efficiency/power benefits are a byproduct of frictional losses, from what I understand.
Old 10-06-2009, 10:02 PM   #20 (permalink)
...beats walking...
...remember, GM "made" their diesel burner engines from basically stock V8 engine block assemblies...and that was why they didn't last (among other reasons).
Mopar to offer Diesel Swap kit for Wranglers Red EcoModding Central 8 08-09-2011 07:23 PM
Why is diesel so expensive in the UK? Eddles Off-Topic Tech 17 10-01-2009 11:50 AM
Canceling out pumping losses of throttle governed engines greasemonkee EcoModding Central 60 08-03-2009 05:24 PM
Diesel Power Magazine Fuel Economy Shootout JQmile EcoModding Central 3 03-18-2009 10:23 PM
As I Had Thought Big Dave General Efficiency Discussion 54 09-03-2008 12:00 AM
