Old 07-15-2008, 11:41 PM   #11 (permalink)
SilverStang - '00 Mustang
90 day: 22.23 mpg (US)
Originally Posted by 1.5Ldave View Post
craigslist.com is usually a good place to check for cars locally
Hey thanks I'll check that out then
Finally got my 20% above EPA
Old 07-16-2008, 03:11 AM   #12 (permalink)
EP3
EP3's Avatar
02WhiteEp3 - '02 Civic Si
90 day: 28.35 mpg (US)
Send a message via AIM to EP3
I think maybe getting an old beater car will make you more happy. If I could do the same I would. I know you like your mustang. If you do mods IMO try to keep it cheap. Pay off car, if you want sell and get better mpg car. But that does not mean you can not still get everything out of your mustang mpg wise. Do what you think is best. We all have our own agendas. Heck even try to do some good Hypering and see what the absolute highest you can get.
"There is no such thing as a dumb question.. Just dumb people".
Old 07-16-2008, 10:31 AM   #13 (permalink)
Ex-lurker
i_am_socket's Avatar
Skeeter - '05 Corolla LE
90 day: 35.55 mpg (US)
Just remember with grill blocks that you do need some air to get to the radiator, just not as much as factory. Also check to see where the air intake is so you don't block that off completely.
Here's a sample using your own car pics:
ok, the second isn't one of yours.
In the top pic, the stuff in red can definitely go. I'd probably block the chin hole too. The yellow I'd block and slowly open from the bottom depending on engine temp stability.
In the second, block those side scoops and you can probably do rear skirts pretty easy.
Putting your car's shape thought the flow illustrator, the rear wing may or may not help your aero. Here's a gif. That'll take testing to know for sure.
I like mustangs, my cousin had a similar one. I can't ride in them though because I have to tilt my head to the side to not hit the ceiling and even then all I can see is sun visor
Video: tuft testing (rear) 1993 Ford Mustang notchback MetroMPG Aerodynamics 12 02-05-2011 09:40 AM
110mpg mustang oldschool EcoModding Central 67 07-13-2009 09:19 PM
I'm new and I would like some Ideas please for a 2000 Mustang V6 2000mustang fan EcoModding Central 28 07-14-2008 05:38 PM
Aerodynamic help 2000 Ford Mustang 2000mustang fan Aerodynamics 6 07-14-2008 03:42 PM
1998 Ford Mustang V6. Stanger98 Introductions 11 07-04-2008 06:27 PM
