Old 11-15-2008, 08:41 PM   #1 (permalink)
Boxhead
whokilledthejams's Avatar
Boxy Brown - '04 xB
90 day: 35.48 mpg (US)
Send a message via AIM to whokilledthejams
Showing off my new grille block
It's not the prettiest thing, but since the temperature's dropped 15F during the day today, and it's supposed to snow tonight through tuesday, I figured I'd rig up additional grille blockage.
The pieces:
Prep:
Finished:
Close-up:
It's straightforward enough-- Coroplast, spraypainted, and held in with zip ties. I left a gap in the center as a margin of safety, though I do have a little extra Coroplast left to fill it in if I'm feeling brave. I have yet to gauge how well it works, since the xB has temperature-idiot-lights (blue for cool, none for operating temp, and red for overheating). If the blue light goes off sooner than usual, and the red light doesn't come on, it will be judged a success.
Hopefully, this will slightly help to mitigate the 3-4 mpg I'm losing due to winter gas and cold weather.
Old 11-15-2008, 08:55 PM   #2 (permalink)
Red
Red's Avatar
Fish - '02 Sebring LXi
Send a message via MSN to Red Send a message via Yahoo to Red
Cool. Though isn't the top grille functional?
Old 11-15-2008, 08:58 PM   #3 (permalink)
Boxhead
Boxy Brown - '04 xB
No, the top grille isn't functional at all. The radiator is low and wide, and only served by the two lowest grilles. The top one is actually a solid piece of plastic. I eventually want to smooth that out, because it would look good, but it's essentially pre-blocked.
Old 11-15-2008, 11:29 PM   #4 (permalink)
Red
Red's Avatar
Interesting. Did not know that. Cool
Old 11-17-2008, 10:34 AM   #5 (permalink)
08 xB - '08 xB
90 day: 35.5 mpg (US)
Looks good. You can use cardboard behind the coroplast to space it out to be flush with your bumper.
Old 11-18-2008, 05:58 PM   #6 (permalink)
Boxhead
Boxy Brown - '04 xB
Yeah, it would look a lot better if it was flush. The bottom one is the way it is, because it's just a friction-fit (and I've had that on since July). I'm just too lazy to fasten it another way. I've been brainstorming ways to build a plug for that opening that would look a little neater, but it may have to wait until spring.
The top block isn't meant to be permanent at this point. So far, it seems to help the car warm up a little bit sooner, which is good. Long term results, of course, will be forthcoming.
How does a grille block improve warmup time? fanamingo EcoModding Central 30 05-03-2010 05:13 PM
Temperature controlled grille block Piwoslaw Aerodynamics 19 11-09-2008 10:24 PM
Best material for grille block? Sean T. EcoModding Central 9 09-09-2008 09:54 PM
Grille block: front or back and top or bottom? 07b2300 Aerodynamics 11 07-07-2008 10:19 PM
Full Grille Block: Upper Grille DifferentPointofView Aerodynamics 12 02-28-2008 10:14 AM
