Old 07-17-2009, 11:48 PM   #1 (permalink)
Grasshopper
alohaspirit's Avatar
Makai - '01 Echo 4D Auto
90 day: 34.45 mpg (US)
Mauka - '00 Echo 4D Auto
90 day: 34.5 mpg (US)
Question Matching Tire Size - Mismatched Brand - Air Pressure
sorry for the edit, info changed around
ok, so i got 4 new tires (90%+ tread) on steelies
3 are sumitomo (51 psi)
1 is "i forgot" (44 psi)
all 4 are 175/70R13
what do i do about tire pressure?
44 to be safe
50 to chance
or throw caution to the wind and go for 60
Past Present Future?
Old 07-19-2009, 10:51 AM   #2 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
I wouldn't inflate passed the maximum a tire is designed for. You would get better mileage gains for moon discs, etc.
Old 07-19-2009, 01:50 PM   #3 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
You'll have to find the load rating for each tire at a given pressure, and inflate them all to a pressure where the load ratings correspond for best handling characteristics. Some tires do not have max load at max pressure, and some do.
They don't need to be even pressures, either. If your Sumi's have max load at 51 PSI, then your other one has max load at 41 PSI, do that.
I'd like to think that people might open their eyes at some point... instead, I find it more and more likely that I'll just close mine.
-- Author kept secret.
Je ne veux pas d'une meilleure vie. Je veux être heureux avec celle que j'ai maintenant.
(I do not want a better life. I want to be happy with the one I have now.)
Old 07-19-2009, 04:30 PM   #4 (permalink)
Grasshopper
thanks for the replies
one of the mpg rules are to max or (overinflate) your tires
so i was curious what everyone would say
Old 07-19-2009, 08:36 PM   #5 (permalink)
Grasshopper
I've run overinflated tires for years... I mean seriously over inflated... and probably over loaded, as well. Still haven't had problems with uneven wear
So which ones better?
Old 07-19-2009, 08:50 PM   #6 (permalink)
I personally run overinflated, but I don't usually recommend it to others. Sure, there might be safety concerns, and that's why I don't offer it as advice normally.
For me, overinflated helps with laziness as well as mileage. I hate checking my tire pressure. YMMV.
Old 07-19-2009, 09:11 PM   #7 (permalink)
Grasshopper
I usually go over too
but i wonder if im making too much of a deal out of this
im just not used to running different tire brands
Old 07-19-2009, 09:18 PM   #8 (permalink)
Just do what I said earlier until you can get a replacement tire that matches the Sumi's, so you can use the "I forgot" (never heard of that one... ) for a full size spare.
Old 07-19-2009, 09:30 PM   #9 (permalink)
Grasshopper
i think its a bridgestone (still not sure)
im not going to be getting another tire so these are IT
so i guess ill go recommended max on all 4
i got the set for $60 btw
MetroMPG.com mailbag: what about lightweight rims? MetroMPG EcoModding Central 19 10-07-2011 03:08 PM
Smooth rims? Eco-Noob Aerodynamics 30 03-06-2009 08:47 PM
Tires and Rims abshnasko Aerodynamics 22 06-14-2008 02:50 PM
WTB or TRADE for HX rims Nden For Sale 12 06-04-2008 05:35 AM
FS: Set of (5) VX Rims with LRR Tires XFi For Sale 2 02-16-2008 03:49 PM
