Old 04-12-2010, 03:19 PM   #1 (permalink)
Go Green Guru
side streets vs freeway
I've been trying the hypermiling advice since I recently purchased a new car... so far so good, but I'm sure I can do better. Question though... I've noticed that if I take the freeway to work I'm able to maintain a constant speed, but there are quite a few inclines.... if I take side streets it's exactly half the distance and I'm able to cruise on neutral for a good amount of time, except of course for the occasional red lights and braking. What should I do?
Old 04-12-2010, 03:29 PM   #2 (permalink)
Vulcan - '05 Vulcan 500 LTD
90 day: 60.08 mpg (US)
Mag Pearl - '011 Fiesta SE Hatch
90 day: 45.91 mpg (US)
Half the distance is always my choice. I can usually beat my freeway MPG on side streets.
The only negative would be if the side streets were a plague of untimed red lights of stops signs at every block.
regards
Mech
The Following User Says Thank You to Old Mechanic For This Useful Post:
sofunkyitsfresh (04-12-2010)
Old 04-12-2010, 03:40 PM   #3 (permalink)
Pishtaco
SentraSE-R's Avatar
Clean Green Toaster Machine - '06 xB
90 day: 45.81 mpg (US)
Generally speaking, the lower your average speed, the better your mpg, all other things equal. If your city streets route doesn't involve too many starts and stops, you may beat your highway route for mpg avg. The easiest way to find out is use your iFCD or Scangauge to compare the routes.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
Mean Green Toaster Machine
49.4 mpg avg over 30,375 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
45.8 mpg over 2235 miles, 164% of '08 EPA
The Following User Says Thank You to SentraSE-R For This Useful Post:
Old 04-12-2010, 04:30 PM   #4 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
Team Saturn
90 day: 43.05 mpg (US)
sofunkyitsfresh -
Even if your MPG is lower, 1/2 the distance is probably going to mean less $ spent at the pump :
40 miles at 40 MPG = 1.00 Gallons
20 miles at 30 MPG = 0.67 Gallons
It sounds like you have a good opportunity to crunch the numbers and see if it pans out. Over time you will perfect your route and learn the lights. Different cities can have different timing. It seems to be a function of the wealth of the city.
CarloSW2
American Solar Energy Society
The Following User Says Thank You to cfg83 For This Useful Post:
Old 04-13-2010, 05:06 AM   #5 (permalink)
aero guerrilla
Piwoslaw's Avatar
Svietlana - '05 307 SW
Diesel
90 day: 55.98 mpg (US)
I'm with Carlos: it's not the MPG's that count, it's the amount of fuel used. If you have a ScanGauge or other MPG-instrumentation, then you can set it to show you the fuel used for the trip, or calculate it by dividing the distance by MPG. Try both routes for a few days and compare.
Piwoslaw's Peugeot 307sw modding thread
Old 04-13-2010, 02:00 PM   #6 (permalink)
Go Green Guru
I would take the bus, but I get off from work really late and I'm a young lady in a ghetto neighborhood, that just doesn't workout here all that well. Thanks for the advice though.
Side mirror drag & effect on fuel economy - quantified MetroMPG Aerodynamics 136 04-15-2012 04:32 PM
Side View Mirror Downsize cfg83 Aerodynamics 20 07-13-2011 12:22 AM
DIY: Side View Mirror Delete, Side View Camera Addition SVOboy DIY / How-to 26 06-07-2010 06:09 PM
Side skirts fastening tasdrouille Aerodynamics 9 08-01-2008 01:24 PM
Naked Streets and Safety SVOboy General Efficiency Discussion 0 11-27-2007 05:11 PM
