Old 04-11-2013, 10:47 AM   #41 (permalink)
Eco taco - '21 Toyota Tacoma Sr access cab
90 day: 22.72 mpg (US)
More current decreases efficiency or over voltage on the wire/ coils. So you could increase the voltage and coils it really wouldn't. But I forgot that hey all don't have to be powered which is a good point
Old 04-05-2014, 12:06 PM   #42 (permalink)
SIM-HAL, new electric all wheel drive Prototype
SIM-Drive's latest wheel-motored prototype is a sporty coupe
Length/Width/Height 4910mm/1835mm/1405mm
Weight 1510kg (3,328 lbs)
Max Seating Capacity 2
Drive Type Outer Rotor Direct Drive In-wheel Motor
Drive Wheel 4
Minimum Turning Radius 5.5m
Single Charge Drive Range (JC08 Mode) 404.1km (*1) ....= (250 mile range)
Drive Energy Consumption(JC08Mode) 86.9Wh/km (*1) = (140 whmi)
Maximum Output 260kW (65kW per motor)
Maximum Torque 2480Nm (620Nm per motor)
0 to 100km/h acceleration 4.70 sec. (with 205/40R17 tires) (*1)
Maximum Speed 180km/h (*2)
Battery Capacity 35.1kWh (Lithium- ion)
Battery Charge Time 1hrs (80% charge by CHAdeMO charging station)
Also see SIM LEI (white)
http://ecomodder.com/forum/showthrea...h-16672-3.html
SIM WIL (blue)
http://ecomodder.com/forum/showthrea...tml#post298032
SIM CEL (black and grey)
http://ecomodder.com/forum/showthrea...tml#post365150
I try to be helpful. I'm not an expert.
