Old 07-01-2009, 06:53 PM   #1 (permalink)
Simple 2 or 3 LED rich/lean 4wire O2 sensor indicator
Hi All,
Has anyone used a simple rich/lean indicator connected to a typical car's standard (4-wire) O2 sensor as a driving aid?
e.g.
red for > 0.55V
yellow for 0.4 - 0.55V
green for <0.4V
(exact voltages may vary)
So that the driver has feedback on keeping the ECU out of rich/power mode?
Maybe it can be simplified to red/green with a threshold at 0.45V, or a single on/off LED...
Cheers.
Old 07-02-2009, 03:11 PM   #2 (permalink)
Manic Rabbit
Southcross's Avatar
Slow-n-Low - '81 Rabbit S
90 day: 33.97 mpg (US)
DIY Air / Fuel Ratio Meter
Cheers
-Edward
Driven on Colorado roads, where NOTHING is flat
Present City 3x / Highway 4x
Goal: 4x / 5x
Old 07-02-2009, 03:59 PM   #3 (permalink)
Manic Rabbit
Southcross's Avatar
also by circumchance researching something else, came across this thread:
Any one seen these DIY gauges?
-Edward
Goal: 4x / 5x
LED Headlight captainslug DIY / How-to 82 11-15-2011 02:32 AM
Converting Cali Civic VX to Fed (lean burn) VX NachtRitter DIY / How-to 34 10-10-2011 11:01 PM
Running "Lean" with a Resistor Divider on the Air Temp Sensor steensn EcoModding Central 22 05-16-2008 10:11 AM
