Simple question: 2003 Toyota Echo or 2003 Civic
If you had your choice of a car to eco-mod, which would it be: a 2003 Toyota Echo Sedan w/automatic transmission or a 2003 Honda Civic Sedan with a manual transmission? (Looking, of course, at overall fuel efficiency as the goal, here.)
Honda Civic w/ a five speed would be my choice only because of transmission (not that there's anything wrong with it, just an Echo standard would beat it in my opinion). Paying attention, and being moderately careful, one should always be able to keep highway MPG in a standard*. Save rare occasions like NYC driving, terrible snow storms, so on. |
The automatic will lose a small amount of efficiency compared to the manual. But the Echo curb weight is listed at 2035 lbs and the Civic is 2403 lbs. I think the weight difference more than makes up for the automatic. EPA: Echo 31 Civic 30 (combined) The Echo is smaller than the Civic so if you make mods to reduce cda you'll be ahead as far as wind drag too. I'd take the Echo, I see it as a better starting point. -mort |
The weight difference would have more of an effect with a lot of stop and go driving than highway driving. Once it's rolling, the weight doesn't matter as much. I personally would go with the Civic 5 speed because of the manual transmission. You can tailor your driving style to suit your needs easier. The manual allows for more adjustment of "the nut behind the wheel". :snail:
I'd definitely go with the Civic and manual Trans.
Reasons: 1) I like Toyotas but the Civic is a larger more attractive car but can get about the same FE 2) Manual Trans is better if your serious about FE because an auto doesn't up shift or lockup the torque converter soon enough for max FE . I have read on here and it's my experience that low rpm high throttle opening is a more efficient way to accelerate 3) resale value |
go with the manual civic or try to find a manual toyota echo;)
Either one, but equipped with a manual transmission. Automatics will lose 10-20 mpg to a manual under a wide range of conditions.
I appreciate the advice, guys. I'm going to make certain that I go with a manual transmission.
:turtle: |
