Old 05-14-2009, 09:25 PM   #11 (permalink)
EcoModding Wannabe
NachtRitter's Avatar
RippinRoo - '05 Legacy Wagon 2.5 GT
90 day: 22.36 mpg (US)
RedHead - '02 R1150RT
Maus - '94 Civic VX
90 day: 51.36 mpg (US)
Originally Posted by daqcivic View Post
They were developed for brake cooling efficiency, not (primarily) for making the airflow at the outer side of the wheels less turbulent.
<snip>
In short, the design is not for making the brakes cooler, but for improving aero efficiency (mainly downforce).
I think I missed something ...
Old 05-15-2009, 03:43 PM   #12 (permalink)
smooth
I got to see Danika Patrick's Indycar at a recent Good Guy's show.The inside of the wheels had full Bonneville-style carbon-fiber covers with only marginal cut outs for wishbones.Beautiful.This is common practice on the salt flats.
Old 05-15-2009, 05:45 PM   #13 (permalink)
QuickLTD's Avatar
Flying Brick - '96 Bonneville SE
Last 3: 22.85 mpg (US)
Send a message via AIM to QuickLTD Send a message via Yahoo to QuickLTD
Found this close up.
1996 Pontiac Bonneville SE 3.8L V6
Old 05-15-2009, 08:57 PM   #14 (permalink)
daqcivic's Avatar
Daq Civic - '92 Civic DX sedan
90 day: 44.26 mpg (US)
The brake temps they need to achieve remain constant and that is not a significant challenge in itself, that is why I said the end goal is not brake cooling. Their end goal is downforce, which requires greater aero efficiency of the rear wing, which requires smoother airflow across the length of the body. The brake ducts create turbulence in that airflow, so if they can make them smaller (while still cooling the brakes) the rear wing will be able to generate more downforce.
The wheel covers are not there to reduce drag across the outer surface of the wheels (even if they do that); they are designed to allow smaller brake ducts—improving brake cooling efficiency—which in turn improves the aero efficiency (downforce generation) of the car overall.
Old 05-16-2009, 02:48 AM   #15 (permalink)
EcoModding Wannabe
Maus - '94 Civic VX
Ah, I see what you're saying... makes much more sense now!
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 857 11-16-2009 01:33 PM
Help with my aero mods: 1.8L 05 Auto Toyota Corolla blackjackel Aerodynamics 67 09-25-2009 10:32 PM
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 52 07-20-2009 11:26 PM
Rear wheel skirt / cover question pasadena_commut Aerodynamics 5 02-16-2009 05:50 AM
Win $100.00 in Free Gas! Design Contest: Ecomod my Ride XFi EcoModding Central 114 09-09-2008 03:41 AM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.3.2
