Old 03-08-2011, 07:47 PM   #1 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
Smooth wheel covers - what size pizza pan?
For those of you who have done the pizza pan smooth wheel cover mod, what size pizza pan did you use compared to your wheel size? I am looking to put them on the Prius, so I measured the wheel and it is a 15" wheel, but the steel lip is 16" diameter. Also, there is a question of the pizza pan size too. Is a 15" pan actually 15" in diameter, or is it made to fit a 15" pizza and have a lip that makes it larger?
Old 03-08-2011, 08:43 PM   #2 (permalink)
Bookworm
fjasper's Avatar
Sylvio - '02 allroad quattro Biturbo 6-spd
90 day: 19.84 mpg (US)
Whitey - '88 80 quattro
90 day: 26.84 mpg (US)
Bertie - '99 Miata
90 day: 30.27 mpg (US)
Kate - '03 Katana 600
90 day: 40.83 mpg (US)
FWIW, the pizza pans I ordered were almost exactly the nominal size. 18" pan is about 17 15/16" in diameter, edge to edge. This is about 3/4" smaller than the diameter of the visible metal part of the 17" wheel.
The Following User Says Thank You to fjasper For This Useful Post:
Daox (03-09-2011)
Old 03-09-2011, 08:53 AM   #3 (permalink)
CM400E - '81 CM400E
That is quite helpful! I'll get 16" pans then.
Old 03-09-2011, 10:22 AM   #4 (permalink)
BamZipPow's Avatar
BZP T-100 (2010) - '98 T-100 ext cab - 3.4L/auto SR5
90 day: 20.99 mpg (US)
BZP T-100 (2011) - '98 T-100 ext cab - 3.4L/auto SR5
90 day: 20.93 mpg (US)
BZP T-100 (2009) - '98 T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (current) (2012) - '98 T-100 ext cab - 3.4L/auto SR5
90 day: 19.56 mpg (US)
Send a message via ICQ to BamZipPow Send a message via AIM to BamZipPow Send a message via MSN to BamZipPow Send a message via Yahoo to BamZipPow
Why not just make them out of coroplast?
Lighter, cheaper, less prone to damage other vehicles if it comes off...
The Following User Says Thank You to BamZipPow For This Useful Post:
johnlvs2run (03-09-2011)
Old 03-09-2011, 10:30 AM   #5 (permalink)
Empty Pocketed Ecomodder
Gen - '05 Liberty Sport
90 day: 22.09 mpg (US)
Blurry - '03 Focus SE
90 day: 35.31 mpg (US)
Bam, how did you attach the disc? is that the screw head i'm seeing there?
Old 03-09-2011, 10:32 AM   #6 (permalink)
BamZipPow's Avatar
Wink
I tried hot glue at first...didn't hold to my alloy rims.
Then I tried...Gorilla Glue. Worked just fine...until it comes time to pull them off. It takes a little to break the bond but you can work it off a little at a time.
The hole you see is the tire valve...
I'm gonna run by the local Discount Tire and git some of their scrap tire weights and see if I can use the steel clip part after I melt the lead off and use those to keep the covers on with.
Old 03-09-2011, 10:34 AM   #7 (permalink)
what did you use to cut the disc's?
Old 03-09-2011, 10:58 AM   #8 (permalink)
BamZipPow's Avatar
Talking
Being coroplast...a sharp Xacto knife. Carefully measured the rim and where the cover was gonna sit into. The diameter was slightly less than the Walmart pizza pan. I just held the pan down and cut into the first skin layer of the Coroplast. Pulled the pan off and then finished the cut. Used one of those Stanley shaver/planers to trim it down to size. To git the valve hole, I just pressed hard where the cap was and then drilled it out with a ½" drill bit. Primed it with plastic primer and then painted them with flat black paint.
My material of choice was those small political signs...I think they were 18" x 24". I have a ton of those from the last election. I could probably make 5 more sets.
Old 03-09-2011, 12:18 PM   #9 (permalink)
Bookworm
fjasper's Avatar
Bertie - '99 Miata
You are correct. Dangit, now what am I going to do with these 18" pizza pans?
Old 03-09-2011, 12:35 PM   #10 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
...anybody eat pizza?
