Old 09-04-2008, 07:49 PM   #11 (permalink)
Diesel Fan
Stealth TDI's Avatar
'98 Stealth TDI - '98 Jetta TDI
90 day: 47.05 mpg (US)
Send a message via AIM to Stealth TDI
Hello,
I appreciate the input. As I considered, it appears the risks of bondo failure is not worth the gain. In addition to spinning forces, potholes, heat transfer, and other variables may exceed the limits of the bondo. My FE numbers are not consistent enough to do any direct comparisons between open holes and taped-over holes. So I'm not sure about considering the tape. Also, my car is a bit of a show car. So I'd want whatever I choose to look pristine.
What I still don't know is if smooth wheels yield significant results or if it is one small step of many to achieve significance. Regardless, I will hold off for a while and test my options later.
Originally Posted by Sandy View Post
Not to hi-jack this wheel cover thread,
but here is a picture of my "grand-daddy" hf antenna.
http://www.yankeecruisah.com/w1cgs/p...-rear-side.jpg
I have my eye on the the Sidekick. I'm saving up for one 'cuz the ATAS sux. I will stay with a center mounted location to perhaps hide some of the antenna behind the draft of the cabin for (hopefully) slightly better Cd.
Take Care,
Scott
'98 Jetta TDI (puff, puff, pass...)
Old 09-04-2008, 09:09 PM   #12 (permalink)
bhazard's Avatar
The TC - '88 Thunderbird Turbo Coupe
90 day: 28.03 mpg (US)
I think its safe to say bondoing the wheels to make them smooth would completely fail, sorry.
Its made to fill dents, as said above. Its also meant to be used on the body of the car, which is on a suspension. The wheels feel a lot more of every bump in the road than the body.
Its easy enough to pull bondo off a rusty old car, what makes you think its gonna stay on a wheel.
BP+T/G5MR swapped '93 Festiva
Escort GT Block, Garrett T3 50trim, A/R .42/.48
SRT-4 Intercooler
---Bests with BP+T---
1/4 mile ET - 12.99
1/4 mile MPH - 109.8
Best MPG - 36.8
Average MPG - 31 (over 11,500 miles)
Old 09-04-2008, 10:39 PM   #13 (permalink)
ooo ooo ooo ah ah ah
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
1. Too heavy
2. Fair amount of work
3. Gain so small you probably couldn't detect it.
Experiment: smooth wheel discs tested A-B-A - 4.6% mpg improvement @ 65 mph Concrete Aerodynamics 266 05-23-2012 10:39 PM
DIY: plastic rear wheel skirts (Geo Metro) MetroMPG DIY / How-to 34 01-06-2012 11:40 PM
Help with my aero mods: 1.8L 05 Auto Toyota Corolla blackjackel Aerodynamics 73 11-22-2011 09:55 PM
Rear wheel skirt / cover question pasadena_commut Aerodynamics 5 02-16-2009 04:50 AM
Modded wheel covers to make them smooth MetroMPG Aerodynamics 1 11-27-2007 08:43 PM
