03-18-2010, 04:00 AM
This snowplow 'thingy' reduced the engine compartment pressure by....
I cut a small hole in the highest pressure area of this van's engine cover and installed a rubber hose. I got a clear plastic bottle half-filled with water and inserted this hose partially beneath the water surface.
I ran this van to 45 MPH by the time bubbles started to surface. This was in stock configuration.
I then 'installed' the snow plow and couldn't get any bubbling at 68 MPH. I slowed down since the speed limit was 60 and traffic didn't warrant a higher speed.
I never re-tested this at a higher speed and my question was/is: how many 'inch-pounds' were there before and after the snow plow change.
The fact that I wasn't getting any bubbles at 68 MPH obviously proves that the air was flowing easier 'around' this vehicle.
My Q is: Does anyone know the 'approximate' inch-pouns of pressure under the average hood, say at 60 MPH?
THX in advance!
GreenTruckingConcepts.com
03-18-2010, 07:57 AM
Pressure is measured in PSI (pounds per square inch) but with the data given there's no way I know of to calculate anything for you're experiment other than the fact that you did reduce the pressure in the engine compartment.
Maybe if we knew the diameter of the tube, the depth of the liquid and where the end of the tube was in the liquid the bubble threshold could be found but even then all you would know is you were over this pressure first and then under this pressure second, but still no way to know how far.
03-18-2010, 01:11 PM
I for one think that bare wood "plow" needs to be painted with something sinister like evil teef or something.
2001 ZR2 Blazer e85/gas flex
03-18-2010, 02:12 PM
...beats walking...
...like the "sharks teeth" painted on Curtis P-40 Warhawks by Claire Chenault's American Volunteer Group (AVG).
• 2011 Chevrolet Cruze LTZ 1.4LT 6A
• 2009 Pontiac Vibe 1.8L/SIDI 4A
• 2004 Pontiac Vibe 1.8L/MFI 4A
• 2003 Ford Focus ZX5 2.0L/Zetec 4A
• 1971 Dodge Charger 318 3A
• 1970½ Plymouth AAR 'Cuda 340/6BBL 4M
• 1968 Dodge Charger 383 3A
• 1967 Plymouth Barracuda Formula S 383 4M
• 1965 Plymouth Barracuda Formula S 273 4M
03-18-2010, 02:29 PM
The pressure won't come close to 'one' PSI in the engine compartment. Paint booths in body shops have a guage that measures 'increments' of a pound. I think I need to install one of these to find out.
THX
03-18-2010, 04:10 PM
is not covered in bees.
Car - '92 Legacy L (sedan) 90 day: 32.49 mpg (US)
I agree with Robert, there's no way to determine an actual number using this method. I do have a suggestion for a method that would be a lot more precise, and that I'm sure someone could devise a way to get actual pressure readings from.
For this method you'll want a road that's as straight and level as possible, and one where you can drive at a consistent speed.
Get a flat piece of wood (like plywood, say), about two feet high and about a foot wide. Also get a length of clear tube, I would say about four feet might suffice. Finding the right size of the inner diameter of the tube might require some experimentation, but I'm thinking maybe a half inch might do it. I imagine air tubing for a fish tank pump would be too narrow (but I don't know).
Fasten the tube in a U-shape onto the wood (without puncturing it), so that the upright portions of the tube are vertical and straight, and that the curved bottom part is not pinched enough to stop water from easily flowing through it.
Find somewhere in your vehicle to secure the piece of wood, where it is visible, so that it's vertical and doesn't move, with the open ends of the tube at the top. (you might also put it somewhere where the water accidentally spilling out won't ruin anything) Pour water into the tube (funnel will be handy) so that it's about half full.
Run that hose that's hooked up to the place in the engine bay where you're testing air pressure over to the clear tube, and connect it to the top of one of the open ends of the clear tube so that it's airtight. Leave the other end of the clear tube open.
Now, get in your car and start driving (without the plow at first, I'd recommend). This is where we experiment on if the clear tube is the right size or not. If the water levels don't move at all, or move so small a distance it would be difficult to measure changes (like, less than an inch), the clear tube is too big in inner diameter (or the connection's not airtight, or there's a clog in the hose, or the tube is pinched shut on the bottom). If water flows out the open end of the tube, or if you see bubbles passing through the water) then you need a clear tube with a larger inner diameter (or a smaller hole at the testing area).
Once you have the right size tube where the water will move a good amount at the speed you want to test (maybe about 3 to 6 inches), you can start comparing air pressures from different modifications. Mark where the water level is while the vehicle is stopped, and then mark where the water level is while at speed. You can compare the different water levels with and without the snowplow thing (and other mods as well), and this will give you a more precise comparison of the effects of different mods, even if you don't know the actual air pressure units. And if you supply the diameters of the hole, the hose, and the tube, as well as the water level changes, some enterprising individuals on here might even be able to calculate the actual pressure units.
This method could also be used to measure the pressure on the outside surfaces of the car, both high and low pressure areas. You could even do it without the holes in the car, just use a small enough hose at the location you want to test the pressure of, and make sure that the airflow isn't blowing directly into the hose. (I think pointing the test hose away from the wind would work best, if it's small the wake of it shouldn't mess with results too much, and at any rate it's located against the body of the car where airspeed is lowest, and pointing away would likely be more consistent than pointing it towards)
03-18-2010, 05:09 PM
I'm not sure how useful this information would be. Having a few ounces per square inch under the hood benefits you how??
I think if you put a knife edge at the front of that thing, your road-kill will be a lot easier to butcher! Yuummmm!
The Following User Says Thank You to thatguitarguy For This Useful Post:
03-18-2010, 09:45 PM
A bubble bottle will measure the pressure difference between its two ends, but neither one is likely to be at atmospheric on a moving vehicle. You get about 1 oz of water pressure at 1.5" deep.
I tried a home-made pitot-tube rig on a boat once, and couldn't get it to agree with theory even approximately.
03-18-2010, 09:54 PM
#9 (permalink)
...beats walking...
..."metering orifice"
03-19-2010, 04:31 PM
#10 (permalink)
units
THX in advance!
If you were looking for your 'ram' pressure at 60 mph,you'd be working with inches of water column pressure.Dwyer makes some reasonably priced pitot-tubes,U-tube manometers,and magnehelics which will provide you accurate low-pressure readings.
The 'snow plow' has completely blocked the ram air from the engine bay.If you can get a look at Hucho's book,I believe he has complete pressure profiles for some cars where you might see what you're interested in.
