Old 06-17-2009, 08:39 PM   #21 (permalink)
Red Wrangler - '98 Wrangler Sport
90 day: 15.67 mpg (US)
Wife's car - '01 Sentra GXE
90 day: 29.31 mpg (US)
GPH.......MPG
LP..........LOD
MPG-self explanatory
I use LOD when I can DWL. I use LP to keep my self in closed loop on acceleration whenever possible. GPH is mostly just gee-whiz info, I haven't though what else to put in that spot. I don't generally try to maintain constant mpg during acceleration, just during steady driving. Brief low mpg during acceleration followed by coasting seems to give the best average mpg.
Old 06-17-2009, 10:14 PM   #22 (permalink)
Vibe - '07 Vibe
90 day: 47.11 mpg (US)
I have 6 items I want to see:
Big Current MPG on MPGuino
car has OEM tachometer
MPG --- LOD
VLT --- FWT
Current MPG lets me see how things are adding up.
Tachometer - a must for shift points
MPG - for instant readout
LOD - watching to keep around 75 during pulse
VLT - i have starting issues of volts drops to 11
FWT - I have found FE is better if I don't push the engine hard until it's over 148f
also: sometimes I will swap out VLT for an x-gauge of current trip average speed.
Old 07-26-2009, 02:45 PM   #23 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.85 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 28.75 mpg (US)
...this question sounds like an excellent candidate to be POLL response, ie: select the four items you typically display.
2011 Chevrolet Cruze LTZ 1.4LT 6A
2009 Pontiac Vibe 1.8L/SIDI 4A
2004 Pontiac Vibe 1.8L/MFI 4A
2003 Ford Focus ZX5 2.0L/Zetec 4A
1971 Dodge Charger 318 3A
1970½ Plymouth AAR 'Cuda 340/6BBL 4M
1968 Dodge Charger 383 3A
1967 Plymouth Barracuda Formula S 383 4M
1965 Plymouth Barracuda Formula S 273 4M
Scangauge II vs cruise control rjacob Instrumentation 10 06-02-2011 03:36 PM
Dealer says ScanGauge ruined my PCM and I can't use ScanGauge anymore Markmysite EcoModding Central 55 05-06-2010 07:31 AM
ScanGauge is bad for MPGs Tango Charlie The Lounge 2 08-10-2008 01:29 PM
Scangauge 1 - Some help please! jdubbs_scort Instrumentation 6 06-17-2008 04:26 PM
scangauge coolant temp accuracy? Daox Instrumentation 12 05-03-2008 02:09 PM
