Old 02-12-2009, 11:47 PM   #1 (permalink)
chuckm's Avatar
Exploder - '02 Explorer xlt
Rolla - '02 Corolla ce
90 day: 44.43 mpg (US)
So what's on your scangauge?
Just curious what others generally keep running on their scangauge. Personally, I have the trip mpg (xgauge), mph, instant mpg, and gph.
"Jesus didn't bring 'Natty Lite' to the party. He brought the good stuff."
Old 02-15-2009, 12:47 AM   #2 (permalink)
americasfuture2k's Avatar
SLOLANE - '08 Aveo5 SV
90 day: 30.55 mpg (US)
wrong thread.
If you cant fix it with a hammer, then you have an electrical problem
http://www.cardomain.com/ride/3159589
shutup, im working on it
Old 02-19-2009, 08:08 PM   #3 (permalink)
Hypermiler
brucepick's Avatar
Lean Burn Civic - '97 Civic HX
90 day: 47.09 mpg (US)
TPS - - - - MPG
LBN - - - - aFE
TPS is critical to helping the car stay in lean burn. Has to be <20 to go in. Anything over 31, and it will go out of LB.
aFE is Average Fuel Economy for the current trip. It's an X-Gauge setting based on the avg mpg for current trip. The manual tells how to set up that one.
LBN is Lean Burn, for my Civic HX. Below is the setup for that gauge. I got the setup from a post by MrChoi on another board.
Use the code below to monitor lean burn with the Scan Gauge II.
To Monitor Lean Burn, type in:
TXD 686AF10115
RXF 044105150000
RXD 2808
MTH 000100020000
NAM LBN
and save.
If the value for LBN = 0 you are in lean burn.
If the value is higher than zero, you are not in lean burn.
Check your tire pressure - keep it up !!
We've learned that diet has a closer relationship to cancer than we ever thought. Please see this Wikipedia article on The China Study.
Driving Lean Burn '97 Civic HX, lotsa mods by now! '89 Volvo 240 is semi-retired. I did love that car though!
Old 02-24-2009, 01:00 AM   #4 (permalink)
Now on two wheels!
[SOLD] Highway Warrior - '00 Protege LX 1.6L Manual
90 day: 35.93 mpg (US)
Basic Miata - '06 Miata Touring
90 day: 31.65 mpg (US)
Send a message via AIM to 1337
MPH fWT
MPG LOD
I like the MPH readout because my speedo only shows increments of 2. Water Temp is useful because I'm experimenting with grill blocks, and I want to make sure my engine doesn't warm up enough to trigger the fan. It's always fun to have the current mpg.
LOD is my favorite display; it's perfect for DWL.
Old 02-25-2009, 11:55 PM   #5 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Zombie Insight - '00 Insight MT
90 day: 62.82 mpg (US)
Trip gallons used (that's the quantity I try to minimize), trip mpg, °FwT so I know when to turn on the heater.
Old 02-26-2009, 12:27 AM   #6 (permalink)
  • ATF temp
  • water temp since the factory gauge is just a blank needle ("if it's over there, it's cold... if it's somewhere in the middle it's OK, if it's over there by the red part it's hot" )
  • don't particularly care
Old 02-26-2009, 08:27 AM   #7 (permalink)
chuckm's Avatar
I use my GPH as an approximation of DWL. I use it as a way to ensure a "steady foot" driving technique.
Shovel: Why do you use the ATF temp? Even though it does affect FE, it seems like it would be something you can't directly control.
Old 02-26-2009, 11:43 AM   #8 (permalink)
I don't use scangauge as a fuel efficiency tool... but I do use my truck for "very rough service" in Arizona - and transmissions are expensive. When the trans fluid is over ~210 or so, I stop & idle (only happens on long/steep inclines now that a large aux. cooler is fitted) - the factory equipped warning lamp only illuminates when trans temp exceeds 290F - juice doesn't last long at that kind of temp
Old 02-28-2009, 09:38 AM   #9 (permalink)
Hypermiler
brucepick's Avatar
Lately I've been showing water temp in lower right corner.
Don't want to run hot in warmer weather. I put the grill block on during winter so I don't know exactly what effect it will have in warmer weather.
Old 02-28-2009, 04:22 PM   #10 (permalink)
Mica Blue - '05 xA RS 2.0
90 day: 45.16 mpg (US)
Josepha - '08 xD
90 day: 30.76 mpg (US)
Average Gas Mileage --- Water Temp (F)
Instant mileage --------- Throttle position
Scangauge II vs cruise control rjacob Instrumentation 10 06-02-2011 03:36 PM
Dealer says ScanGauge ruined my PCM and I can't use ScanGauge anymore Markmysite EcoModding Central 55 05-06-2010 07:31 AM
ScanGauge is bad for MPGs Tango Charlie The Lounge 2 08-10-2008 01:29 PM
Scangauge 1 - Some help please! jdubbs_scort Instrumentation 6 06-17-2008 04:26 PM
scangauge coolant temp accuracy? Daox Instrumentation 12 05-03-2008 02:09 PM
