Old 11-11-2011, 03:42 PM   #1 (permalink)
The Antichrist - '95 Discovery Plain Jane
90 day: 12.7 mpg (US)
So... Who wants to try my new idea?
Take any Car, the lower the better, preferably 4 ft wide, more I you can buy wider material. Buy some plexiglass. THe more the merrier. Mount a 4x8 sheet on the roof and have it gently curve down until it touches the end of the hood. Mount the next sheet where the prior one ended, and carry on wih the arced plexy until you almostoch the road, maybe 4 inches up On the back do the same, until the car resembles an upside down dinner plate, or a speed bump, or a trapezoid with curved angles. The sides can also be covered with plexi, covering the wheels and mounting to the front and back pieces for support. if you feel energetic you can cover the belly of the car and eliminate all turbulent areas. Well almost.
I realize I might add a few pounds, extend the lenth of the car by a few feet, but it would be super aerodynamic. Almost No need for any other aero mods.
Old 11-11-2011, 04:47 PM   #2 (permalink)
ooo ooo ooo ah ah ah
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
You are not aware that basjoos did almost exactly that?
Old 11-11-2011, 06:58 PM   #3 (permalink)
Patrick's Avatar
Hot Tamale - '010 Prius III
Problem is you gotta keep it clean and Plexiglass scratches easily.
Old 11-11-2011, 07:09 PM   #4 (permalink)
Blue - '93 Tempo
F150 - '94 F150 XLT
Good luck with defrosting/defogging it too, as well as seeing through the rain- yes motorcycles don't have wipers on their fairings, but most of us look over the fairings more than through them.
Old 11-11-2011, 07:21 PM   #5 (permalink)
Big Blue - '06 Dakota Quad SLT
90 day: 20.36 mpg (US)
Miazda - '96 Miata mx-5
90 day: 44.14 mpg (US)
sides
The open spaces on the sides will cost you in aero. That is if they don't allow enough air in to rip it all apart
Old 11-11-2011, 08:24 PM   #6 (permalink)
That's why I said plexi on the sides too. No I did not know desjoos did that. Did it work?
Old 11-11-2011, 08:29 PM   #7 (permalink)
Blue - '93 Tempo
F150 - '94 F150 XLT
As far as I know he took it off.
Old 11-12-2011, 03:53 AM   #8 (permalink)
Schwinning!
Sven7's Avatar
The Anal Probe - '92 Probe GL
Team Ford
90 day: 35.92 mpg (US)
I think the problem was usability. Like others mentioned, it fogs up easily, is difficult to clean, has no wipers, distorts vision, etc.
If you want to remove your stock windshield and build a new one over the hood be my guest! That would be cool to see.
Originally Posted by Weather Spotter View Post
Nothing fell off so that is good.
Old 11-12-2011, 01:38 PM   #9 (permalink)
Absent without leave.
Arragonis's Avatar
George - '011 Aygo Go!
Team m8
90 day: 54.54 mpg (US)
Mildred - '011 Prius T-Spirit
90 day: 45.97 mpg (US)
The legend that is....
No longer here. Bye, and good luck to all.
Old 11-12-2011, 08:51 PM   #10 (permalink)
JasonG's Avatar
1 Ton - '94 C3500
90 day: 19.7 mpg (US)
Big White Brick - '03 Express Van
90 day: 15.19 mpg (US)
He also learned it made a minimal improvement over a facory sloped windsheild.
Hucho shows a chart of windsheild angles, basically there is minimal change until an angle much more vertical than modern autos have.
As an added point, plexi is much more expensive than foam/fiberglass.
FRF is also easier to shape with a sander or hot wire.
Support Bennelson !
I can't understand why my MPG's are so low..........
16000lb, 41' Toy Haulers are rough on FE!
