Old 01-02-2010, 08:25 PM   #1 (permalink)
1.4 TDI - '03 Ibiza
90 day: 49.68 mpg (US)
Solar panels by IKEA
Hey ecomodders!
Today went to IKEA and thei have this solar panel chandeleers that work with 3 x 1.2v rechargeable batteries. That means 3.6v generated per panel so 3 things like this make 3.6x4=14.4v.
link: http://www.ikea.com/pt/pt/catalog/products/90154371
Would it work on a car to recharge help the battery in a parcial alternator cutoff?
I'm don't know tat much abou electricity so I'm just asking, thought was a good idea!
Thanks!
Old 01-02-2010, 08:54 PM   #2 (permalink)
Mica Blue - '05 xA RS 2.0
90 day: 48.22 mpg (US)
Josepha - '08 xD
90 day: 30.76 mpg (US)
No, the current coming from these tiny panels would not make a dent in the need for the alternator -- sorry. Check for the thread where someone covered the entire roof of his car with a PV panel and he got a small benefit, I think.
Old 01-03-2010, 01:18 AM   #3 (permalink)
gascort's Avatar
Gascort - '93 Escort Wagon
90 day: 43.01 mpg (US)
yeah, the whole roof in panels puts out enough on a sunny day to allow me to drive for about 45 minutes. (summer)
Winter and I probably get enough to run for 20 minutes.
Those little guys probably have current ratings or wattage ratings so you could figure out how much power they have.
Power = voltage * current
(Watts = volts * amps)
If you have 2 watts of solar panel and you have it in direct sun for 3 hours, you have 6 watt - hours
Your car probably requires about 200 watts minimum to run (source)
6 watt hours divided by 200 watts = 0.03 hours that you could run your car on stored solar energy.
You might not even see gains from disconnecting your alternator. I saw negative MPG changes. Now I have a really expensive battery maintainer on my roof, lol. (unless I figure out how to get it to like running at 12V)
Matt
Gasoline, Wind, Solar, Gravity Hybrid-to-be! http://www.scientificmethodfueleconomy.blogspot.com/
Old 01-03-2010, 03:32 AM   #4 (permalink)
Did you use a mppt or a pwm charge controller. The mppt will yield between up to 33% more energy from the same solar cell aray. I am hoping to switch my controller that I use on my camping property up in Washington to the newer, better technology.
Good Luk,
DAve
Matt
Old 01-03-2010, 08:06 AM   #5 (permalink)
1.4 TDI - '03 Ibiza
Matt
So by instaling a switch to the alternator to make a cut off it might not bring any better mpg at all?
About the IKEA solar panels it no would even work for the radio!
Old 08-04-2011, 03:05 PM   #6 (permalink)
SwamiSalami's Avatar
2LT's Tank - '010 Element EX
This is a great concept, though.
The question that still remains is this:
Can a solar panel(s) assist the alternator instead of deleting it? I've asked this I don't know how many times, but to no avail.
Also, attached to this question is the notion that A) you could still drive the car in less sunny weather and B) potentially have no range anxiety, because it's an addition, rather than a substitution.
Thanks
Old 08-04-2011, 03:28 PM   #7 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
...ASSIST? = very positive YES.
...REPLACE? = most emphatic NO.
2011 Chevrolet Cruze LTZ 1.4LT 6A
2009 Pontiac Vibe 1.8L/SFI 4A
2004 Pontiac Vibe 1.8L/MFI 4A
2003 Ford Focus ZX5 2.0L/Zetec 4A
1971 Dodge Charger 318 3A
1970½ Plymouth AAR 'Cuda 340/6BBL 4M
1968 Dodge Charger 383 3A
1967 Plymouth Barracuda Formula S 383 4M
1965 Plymouth Barracuda Formula S 273 4M
The Following User Says Thank You to Old Tele man For This Useful Post:
SwamiSalami (08-04-2011)
Old 08-04-2011, 03:59 PM   #8 (permalink)
Ok, now that we've established the fact that it CAN assist, how much?
what can one expect to gain by doing this?
HAS anyone done this set up (to assist, not delete)?
Old 08-04-2011, 06:59 PM   #9 (permalink)
Josepha - '08 xD
Automotive alternators are 50-100A if I am not mistaken? This laminate 24v 136W (meaning it is about 5.6A) is 15.5" x 216" -- and you would need TEN of them to equal a small alternator. That is 33,480 square inches or 232.5 square feet to get ~50A.
Old 08-04-2011, 07:04 PM   #10 (permalink)
Black Knight - '94 Corolla
90 day: 61.92 mpg (US)
is that all???/
DIY Solar PV panels sold at Lowes NeilBlanchard Saving@Home 20 02-23-2010 10:18 PM
Replace sunroof with solar panels to power AC? Luxbg EcoModding Central 6 08-19-2009 10:23 AM
solar panels vs biodiesel dcb Fossil Fuel Free 6 05-23-2009 12:25 PM
Motor, battery and solar panels for a boat Wywern Fossil Fuel Free 11 02-17-2008 08:22 PM
