05-08-2018, 06:37 AM
#21 (permalink)
16% capacity factor already is amazing considering the poor weather we have been having.
05-08-2018, 12:48 PM
#22 (permalink)
Right - an average of 38.3kWh / day is okay, but not great. We have hit as much as 68kWh in one day.
The estimated annual total for our system was just shy of 13MWh. If we stay at the 38.3kWh / day average, that is almost 14MWh for the year.
05-08-2018, 01:58 PM
#23 (permalink)
Lovely looking house and location Neil.
Did you build the roof pitch to optimize power generation, or to shed snow?
05-08-2018, 02:13 PM
#24 (permalink)
I built the 12 pitch roof to get the most roof space I could reasonably get. It happens to be ideal for winter production, and yes snow shedding off is also important for winter production. My brother's system is on a 5 pitch, and that works better in the summer, but he has to clear snow with a long handled snow rake. Which is non-trivial work.
05-08-2018, 02:20 PM
#25 (permalink)
Can you share a "before" photo? Just curious to visualize what you described.
05-08-2018, 02:40 PM
#26 (permalink)
Rat Racer
Wait, no solar hot water?
Originally Posted by sheepdog44
Transmission type Efficiency
Manual neutral engine off.100% @∞MPG <----- Fun Fact.
The Following User Says Thank You to Fat Charlie For This Useful Post:
05-08-2018, 03:38 PM
#27 (permalink)
Probably better off installing more PV and running a hot water heat pump.
Depending on your homes lay out and where you live, some where cold like MA installing solar hot water can be a real pain because you have to run glycol and run these lines where you don't normally run water lines. That means you could be tearing out walls through 1 or 2 floors in a typical new England style home if your water heater is in the basement.
Actually I would only go through the trouble of thermal solar if I was going off grid and wanted to futlrther reduce my propane bill.
05-09-2018, 08:29 AM
#28 (permalink)
I have a heat pump water heater.
05-09-2018, 08:33 AM
#29 (permalink)
Rat Racer
I was thinking more along the lines of Gary's $1000 solar water heater. The plumbing isn't extensive, but you do need space in the basement.
It beats turning the sun's heat energy into electricity, storing that, and then turning it back into heat again.
05-09-2018, 08:44 AM
#30 (permalink)
I will upload pictures of the old 8 pitch hip roof when I have access to them.
Solar heat collectors with vacuum tubes are pretty good. Maybe someday.
