Old 08-07-2009, 11:58 AM   #11 (permalink)
gascort's Avatar
Gascort - '93 Escort Wagon
90 day: 43.01 mpg (US)
Originally Posted by Piwoslaw View Post
I wonder if the hood is a good idea. First, at certain angles it could cause more glare than the normal hood paint job, blinding the driver. Second, the hood gets warm when after the engine has been operating, and solar cells' efficiency decreases with temperature.
Good points - I'm a bit worried about glare too - will have to test with my spare plexi.
Gasoline, Wind, Solar, Gravity Hybrid-to-be! http://www.scientificmethodfueleconomy.blogspot.com/
Old 08-07-2009, 12:02 PM   #12 (permalink)
gascort's Avatar
Originally Posted by cfg83 View Post
gascort - 100 Watts in 4-5 hours of sun. How many daytime alternator-less miles does this translate to?
CarloSW2
The car probably uses about 300W to drive, plus more for the starter, but that's hard to quantify - I could probably look it up. Assuming 100% efficiency (which my battery and is not) it would be 1/3 of my good sun time. So probably 1.5 hours after efficiency losses and starter use. My commute is only 20 minutes each way, so I should be good without even needing my trickle charger for an average week.
Old 08-07-2009, 12:05 PM   #13 (permalink)
gascort's Avatar
Originally Posted by orange4boy View Post
I need one for my Kammback...
Keep on amping!
Dude, your roof would be great! Probably 2X the area of mine unless it has a sunroof and weird bump in the middle like mine does.
Old 08-07-2009, 12:08 PM   #14 (permalink)
gascort's Avatar
That is really sweet! I love how you have so much area you can use. I'm a bit jealous of that, haha.
Just the other day I was talking to SVOboy about doing something similar. My idea was to use my sunroof and paste the cells to the bottom side of it. This wouldn't nearly the area yours does though.
With you pumping out that many amps, you're probably gonna wanna pick yourself up a charge controller too I'd imagine.
lol, I wasn't even looking for a wagon originally. Everything about it has worked out nicely though; extra space for hauling since I got rid of my truck to buy it, extra room for baby stuff since we had a little one, easier to attach Kammback, and more room for solar array.
I want to build a charge controller. We'll see if I get it built or if I go to Ebay first.
Old 08-07-2009, 12:50 PM   #15 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
This is exactly what I was trying to tell you to do! Exit roof, enter solar!
Old 08-07-2009, 01:30 PM   #16 (permalink)
wagonman76's Avatar
Red Car - '89 Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 6000 LE Wagon
90 day: 28.26 mpg (US)
That's cool. Doesn't look like it would cut into your aero either. Looks great!
I could put a lot of those on the roof of the wagon. Don't think I could go alternatorless though, besides long trips, my engine is a beast compared to the Escort engine (used to have a 92 Escort wagon).
Winter daily driver, parked most days right now
Summer daily driver
Old 08-07-2009, 01:34 PM   #17 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 57.08 mpg (US)
CM400E - '81 CM400E
I did some digging for you (and me). I ended up finding this. Doesn't get much cheaper than this. ~$15 for the kit shipped. It also is a dump load charge controller, so you could say... power your fan if your battery gets fully charged ah-la Prius III. That would be pretty sweet.
ghurd - Hurd Solar Renewable Energy | Dump Controllers
Old 08-07-2009, 03:24 PM   #18 (permalink)
gascort's Avatar
Thanks, Daox - the kit is probably the way to go - I want to get my hands dirty, so to speak, but learn how it works at the same time.
Powering the fan like the prius is a good idea, or if I eventually have an array (planned) atop my garage, I could plug the car's dump load into the inverter! Vehicle -to- Grid!
My car doesn't move much in the summer unless we go out of town; I live in the city, don't work all summer, and ride my bike or walk everywhere I can.
Old 08-08-2009, 11:14 PM   #19 (permalink)
gascort's Avatar
Update - after 2 days of sitting/driving in the sun, no cracks - well, no spreading of the cracks I created. I will take it on the highway tomorrow up to 70 mph so hope everything goes well. I also noticed that since this raised the back end of my roof by about 8mm(the roof curves steeply there so I put washers beneath the plexi and didn't make it conform to the roof's curve), I need to put a couple of washers under the leading edge of my Kammback - it was very perfect and smooth, but now there's a drop-off.
I got the wires ready to install a charge controller, just have to wait for a paycheck to purchase the kit that Daox pointed out.
I also decided on a use for the spare 7.5V string I have up there until I install more on the hood or Kammback - charging my daughter's EV (power wheels ATV) - it's a 6V battery.
Old 08-09-2009, 12:01 AM   #20 (permalink)
marcusmodder
orange4boy's Avatar
The Golden Egg - '93 Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Prius
90 day: 57 mpg (US)
Gascort,
If you have cracks in the plexi, drill a hole (with a dullish drill*) just at the end of the crack then fill the hole with silicone. This is a stress relief technique, that spreads the forces around the circumference of the hole. Stops cracks in their tracks...
*plastic drills should be ground so the cutting edge has a 90 degree rake. You want to scrape the plastic. A normal twist drill will dig in and force the drill through too fast, causing fractures. Barring a way to regrind, use a dullish one, go slow and watch out for overheating. A glass of water can be helpful to cool off the drill if you are doing a lot.
Commercially produced aerodynamic pickup bed cap MetroMPG Aerodynamics 465 02-05-2012 12:07 PM
Replacing alternator with solar panel array on roof? blackjackel EcoModding Central 91 01-19-2012 10:19 PM
xB Solar panel roof trikkonceptz EcoModding Central 10 02-28-2009 04:27 PM
Solar cell panel on the roof..?. Xringer EcoModding Central 5 09-07-2008 02:51 AM
