Old 06-22-2014, 02:35 PM   #1 (permalink)
Solara: Mods that still look good.
Hello Ecomodders, my goal is to get 36+ MPG out of my V6 solara while keeping the good looks of this car. Thus far I am at 32.5 MPG in mixed driving up from 27.6 MPG.
Key mods:
Lower grill is blocked with lexan painted from the inside. This gives the grill a shiny, new car look without going through the pain of getting the paint just right. I started the process using styrafoam to model the odd shape of the lower grill. Styrafoam is inexpensive and easy to cut and shave. Once the styrafoam was built, I actually ran the car with it to test the mod before adding the exterior lexan.
Fog lights have been improved by a smoother lexan cover.
I kept the upper grill unblocked. This allows engine cooling. If you look closely you'll see that the upper grill is fairly airodynamic already. Give the choice between the wide open lower grill and the smaller, more airodynamic upper grill, I chose the upper for engine cooling. Thus far on 90 degree days the engine temperature guage hasn't budged.
The engine air intake was modified to pull air off the hot header pipes. When you add the reduced air intake, this yields warmer air to the engine. This means the engine does not need to enrich the incoming air with a richer gas mixture like it does on cold air intakes. The tradeoff is typically less power which I haven't noticed.
If you look closely, you'll see lexan air dams in front of the wheels. They are small and focused on angling the incoming air to the bottom of the tires. You'll notice many new car manufacturers add these tire air dams for a cheap increase in mileage.
Last thing thus far was to add insulation at the rear of the car to smooth out the airflow below the rear bumper. This has had no noticeable effect on mileage.
Results:
Lower grill: 4 MPG
Fog lights: 0.5-1 MPG
Warm air intake: 1-2 MPG (more on cold days)
Wheel dams: TBD
Rear underside smoothing: 0 MPG
Unfortunately the restrictions on filesizes are preventing me from uploading pics. Any suggestions?
Smoothrunner.
The Following 2 Users Say Thank You to smoothrunner For This Useful Post:
backpacker3 (06-22-2014), California98Civic (07-04-2014)
Old 06-22-2014, 03:30 PM   #2 (permalink)
0.29 Cd and decreasing
Red Rocket - '90 honda CRX HF
Team "Old SKOOL"
90 day: 53.46 mpg (US)
Keep it coming! I use photobucket, you can upload the pictures on photobucket then copy and paste from there and it should work.
Old 06-22-2014, 03:40 PM   #3 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
5 post and you can post pics!!!!
go to the links in my signature and make 4 posts!!!!!
ps....welcome!
have you increased tire psi to 40+?
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 06-22-2014, 06:37 PM   #4 (permalink)
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
I would be very careful with using the stock gauge as a reference, I thought my full lower grill block on the Corolla was fine, but I plugged in my UG when I got it, and it was actually 5F cooler that day then the day before, and under load (I.E city driving) I was getting up to 219F and the gauge was still dead in the middle. I would recommend getting a UG for more accurate testing to make sure your not causing engine damage.
The Following User Says Thank You to Baltothewolf For This Useful Post:
smoothrunner (07-04-2014)
Old 06-22-2014, 08:40 PM   #5 (permalink)
backpacker3's Avatar
Homer - '02 Pontiac Sunfire SE
Team Pontiac
90 day: 30.05 mpg (US)
Nice job on the fog covers! I've been looking to see if anyone had done that yet, I might just try that now
Aiming for 50 MPG from an automatic.
See how I'm doing here, My Build Thread
Old 06-22-2014, 11:08 PM   #6 (permalink)
mcrews's Avatar
here are some clear grille block and fog block
[IMG][/IMG]
ECO MODS PERFORMED:
First: ScangaugeII
Old 07-04-2014, 11:20 AM   #7 (permalink)
Vader - '15 Dodge Grand Caravan
90 day: 23.13 mpg (US)
Cmax - '13 Ford Cmax SEL
90 day: 40.92 mpg (US)
[IMG][/IMG]
mcrews, did you use black tape of some sort to keep your lexan covers on?
smooth looks to have used screws? Nice gains btw!
Old 07-04-2014, 12:19 PM   #8 (permalink)
Is this a convertible? Does the top fit snug? Do you notice it moves while driving?
Wonder if having the vent blowing air inside the car to firm up the top helps or offsets whats used to power the blower?
Old 07-04-2014, 05:41 PM   #9 (permalink)
I think you wouldn't notice either, but for what it's worth turning the blower on max to puff the top up a little hardly gets rid of the "gap" caused by the top sagging between the rails. Besides, the rails are usually not at "template" height. A better solution would be to sew in some extra straps to put tension on it at selected places, or something like that.
The newer Mercedes and Porsche convertible models have very smooth and aerodynamic cloth tops, and I'm guessing they've accomplished that by putting some extra rails and stuff in there.
Old 07-04-2014, 07:30 PM   #10 (permalink)
Winsight - '06 Honda Insight
Gen-1 Insights
90 day: 72.19 mpg (US)
I've thought these look good for blocking off airflow around the wheels. In person they aren't very noticeable.
Toyota Brake Dust Shields - Toyota auto parts
