Go Back   EcoModder Forum > Classifieds > For Sale
Old 04-25-2014, 02:49 PM   #11 (permalink)
NightKnight
NachtRitter's Avatar
RippinRoo - '05 Subaru Legacy Wagon 2.5 GT
Subaru
90 day: 21.16 mpg (US)
Helga - '00 Volkswagen Jetta TDI
Diesel
90 day: 53.91 mpg (US)
Olga - '03 Volkswagen Jetta Wagon
90 day: 46.24 mpg (US)
Researched that too, but it sounded like that's temporary, as the welded manifolds crack again within a relatively short period of time. There's probably a "right" way to weld it, though I don't know which local welder would be willing to do the weld and which would be able to do it "right". It'd probably be enough to smog this time around, but then I expect I'd have to deal with the same issue again next time.
For someone that has the time & inclination, that'd be a reasonable way to go.
Old 04-27-2014, 12:13 AM   #12 (permalink)
Insight for life's Avatar
05 Prius (wife's) - '05 Toyota Prius package 5
90 day: 44.32 mpg (US)
Citrus - '00 Honda Insight
Gen-1 Insights
90 day: 60.68 mpg (US)
Have you sold this yet?
Old 04-27-2014, 12:24 AM   #13 (permalink)
NightKnight
Subaru
Diesel
Not yet
Old 04-27-2014, 12:25 AM   #14 (permalink)
Gen-1 Insights
Did it fail the visual or is it throwing a code or not passing the sniffer?
Old 04-27-2014, 12:32 AM   #15 (permalink)
NightKnight
Subaru
Diesel
It is not passing the sniffer. The smog tech pointed out the crack in the manifold after the sniffer test failed. No codes though.
Old 04-27-2014, 08:26 PM   #16 (permalink)
NightKnight
Subaru
Diesel
This may be sold... will know for sure shortly
Old 04-28-2014, 05:44 AM   #17 (permalink)
90 day: 29.44 mpg (US)
For the record, my JB-Weld seems to have been a complete failure. The exhaust was hitting the heat shield immediately.
Old 04-28-2014, 07:00 AM   #18 (permalink)
mbolton1990's Avatar
eco-crx - '90 honda crx hf
90 day: 56.89 mpg (US)
Yea JB weld isn't going to cut it for that......
Take the manifold completely off,remove the cat/o2 and take it to a welders shop.
I believe standard practice for welding cast (Im pretty sure) includes heating up the cast metal to a certain temperature then laying down the bead/filler.
If you need a welder lmk I know a stand up guy in TX that worst case you could ship it too.
After being properly welded properly it'll be stronger than factory.
At least that's how the 90+ volvo turbo manifolds are that I'm more familiar with.
Best of luck,cool car.
Old 04-29-2014, 03:05 PM   #19 (permalink)
NightKnight
Subaru
Diesel
Car has been sold! New owner picked it up this morning.
Old 12-06-2017, 10:59 PM   #20 (permalink)
I am not understanding. The part numbers of the 49 state and the CA version are exactly the same. Also, there are numerous threads on this site confirming that the only differences between CA and federal versions of the VX are the O2 sensor, the ECU, and the wiring harness. Therefore the original poster could have replaced with a used exhaust manifold from anywhere in the country. Or not?
