Old 12-11-2008, 03:23 PM   #1 (permalink)
Ex-lurker
i_am_socket's Avatar
Skeeter - '05 Corolla LE
90 day: 35.55 mpg (US)
Soldering question
I was about to install my MPGuino, and after some difficulties finding the ECU to tap into (every diagram I could find showed it at the top of the glovebox, so image my surprise when I found it at the bottom) I tried locating the wires I'd need to tap. I've got some rather detailed schematics and pinouts, but the problem is the wires themselves.
I honestly don't think I've ever seen electronics with wires this thin. I had some 22-24 gauge wire ready to go (and some cheater clip taps) but the wires coming out of the ECU are about the size of half the actual cable including the insulation! Clip taps are totally not going to work at all, so I guess I really need to solder the taps in but I don't know if I'll damage the cable irreparably by trying to solder them...
I'll get a pic up in a few for comparison, but should I be worried about damaging the cables or am I just being paranoid?
Old 12-11-2008, 04:11 PM   #2 (permalink)
McTimson's Avatar
The Turkel - '93 Tercel
90 day: 40.39 mpg (US)
Felix - '09 Yaris
90 day: 34.49 mpg (US)
You should be fine, just be careful stripping the area you want to solder. The wire is still metal, it'll probably just heat up faster since it's thinner.
You could also cut the wire, and crimp connections onto the end. Soldering is definitely the more secure way to go, as the crimped connections have a way of falling off after a while, but either way will work.
If you're worried about damaging the wire, then cut open a spot far enough from the connector that you could still crimp a connector on there if you had to. That way, if you can't solder it, you still have the option of putting connectors on there.
Old 12-11-2008, 04:13 PM   #3 (permalink)
Ex-lurker
Here's some pics:
This is the front of the ECU (ECM as toyota calls it). As taken by my phone, upsidedown, about 6" from the floor which makes it pretty darn awkward to work on.
Here's where the ECU is located from a more upright position:
Do you see it? Me neither. Took me almost 20 minutes to track it down by following the bundles. And then there's the "clips" that hold a cover over it that took another 10 minutes to remove (it appears they were designed to be 1 directional).
I don't know if the pinout image I have is positioned upside down or not, without a flashlight to be certain, but it looks like it is. I was going to try to put a regular wire next to the ECU wires for comparison, but no light = fail. The next problem, or rather the pre-curring problem, is that the wires are bundled so tightly I don't know if I can separate them enough to actually get in there to tap them without starting a fire.
But that's slightly easier to get to than the fuse box... What ever happened to cars being easy to maintain?
Old 12-11-2008, 04:28 PM   #4 (permalink)
2k2Prot5 - '02 Protege5
90 day: 33.82 mpg (US)
Cars that are easy to maintain don't bring in 120 bucks/hour at the stealership shop.
Could you possibly considering sourcing the signal from sonewhere else? I wouldn't work in that tight mess... maybe you can pick it up near to the sensor, where the wire enters the car in the first place, near the fuse box... somewhere other than that ratsnest.
Old 12-12-2008, 09:11 AM   #5 (permalink)
You must be joking - '97 Impreza Sport
Would it be possible to piggy-back the wire into the back of the plug going into the ECU ?
It probably depends on the design of the plug but a Molex or similar sort of plug connector (just the metal part) on the end of the wire might push into the back of the ECU harness plug.
Better Off OUT of the EU
Old 12-12-2008, 12:40 PM   #6 (permalink)
wagonman76's Avatar
Red Car - '89 Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 6000 LE Wagon
90 day: 28.26 mpg (US)
I used to love the taps but now I hate them. They work good for awhile, but Ive had too many of them work loose over time. Once was on my trailer brakes. Anymore I always strip and solder and tape. I only want to do the job once, especially in an area as hard to get to as the ECM.
Winter daily driver, parked most days right now
Summer daily driver
Old 12-13-2008, 09:08 AM   #7 (permalink)
Ex-lurker
I might be able to piggy-back the ECU connection at the plug. From the outside it appears to be a molex-like connection. I've got some free time today so I'll see what I can do with the rat's nest.
I just realized I left my color printouts of the schematics at work. I hate printing things out; too bad my phone can't read PDFs yet.
Old 12-13-2008, 03:22 PM   #8 (permalink)
Ex-lurker
Nope, no piggy backing option. Waaaaay too tight in there.
In any event, I finally got the wires tapped (I cheated and used the taps, I'd need to wait till spring at least to get everything set up and I got impatient).
I'll very likely go back and solder once spring or summer rolls around.
Old 12-29-2008, 03:39 PM   #9 (permalink)
Ex-lurker
And a few weeks later:
How does one go about de-soldering? I've seen kits with a soldering iron and what appears to be a large metal turkey baster, but what is actually involved? Do I need that type of setup?
Old 12-29-2008, 06:22 PM   #10 (permalink)
Wannabe greenie
The Clunker (retired) - '90 Accord EX sedan
90 day: 29.49 mpg (US)
Uranus - '04 Ion 2 sedan
90 day: 38.21 mpg (US)
Mountain Goat - '96 Ranger XLT 4x4 SuperCab
90 day: 18 mpg (US)
Zippy - '010 Agility 125
Two ways to go about it: one is the solder sucker, which is like a small turkey baster. Heat up the solder and suck it up. The other is solder wick, which is braided copper. Heat up the solder with the iron, touch the wick to it, which absorbs the solder, and then cut off the end of the wick to expose fresh wick.
I haven't had to desolder yet, so I don't know which is better.
Mini-split ductless question.. Xringer Saving@Home 50 05-25-2010 04:01 PM
Question about EOC with an Auto... :confused: LastBoyScout Hypermiling / EcoDriver's Ed 20 08-30-2008 06:28 PM
Prius Question Matt Herring EcoModding Central 13 07-24-2008 03:07 PM
Question regarding Scangauge MPG readout & DIY device Gregte DIY / How-to 5 05-19-2008 04:58 PM
newb intro and question about civic hb vx reformed Introductions 9 01-29-2008 11:28 PM
