Old 08-03-2008, 08:39 PM   #11 (permalink)
Don't overfill - that makes more heat and cuts efficiency due to spin loss.
As for the add-on pump, it's feasible but make sure that it isn't a restriction to "normal" flow.
Old 08-03-2008, 09:11 PM   #12 (permalink)
Renaissance Man
Formula413's Avatar
Sleepwalker - '97 Firebird Formula
90 day: 20.04 mpg (US)
Spock - '92 VN750 Vulcan
90 day: 49.39 mpg (US)
03MX - '03 Civic Hybrid
90 day: 49.04 mpg (US)
Formula: I just noticed your user title and LOL'd! "I can has ecomodz?" Thanks for the chuckle.
You're welcome.
More choices...
Old 03-10-2011, 09:07 AM   #13 (permalink)
Big Blue - '06 Dakota Quad SLT
90 day: 20.36 mpg (US)
Miazda - '96 Miata mx-5
90 day: 44.14 mpg (US)
Has anyone done this yet? I really need to do something about the auto trans in my Dodge truck.
Old 03-10-2011, 11:04 AM   #14 (permalink)
vacationtime247's Avatar
The S cart - '91 Ford Escort Wagon LX
90 day: 33.66 mpg (US)
Pint-oh! - '78 Ford Pinto Pony
Black Beauty - '89 F-350 Dually Diesel Lariat XLT Crew Cab
90 day: 17.67 mpg (US)
The Toylet - '87 Supra 350 Chevy V8 / 700R4
In-Durrrr-Oh - '09 Enduro TMEC 200cc Enduro
90 day: 60.9 mpg (US)
Tem-poo - '86 Tempo GL 4 Door 2.0 Liter Diesel 5 Speed
90 day: 51.12 mpg (US)
Family Truckster - '92 1992 Diesel Caprice Station Wagon project
Ass Tick - '01 Pontiac Aztek GT 5 Door
DoGo#2 - '99 Durango Dodge Durango SLT
Been putting my car in N coasting to stops for some time now. Mostly in my Escort but even been trying it in my wifes car the Alero. She gives me that 'what are you doing?' look. Way I figure it, an Escort tranny is cheap. Like @$250-$350 used from the recyclers. If it breaks, I'll do the repairs myself. Or perhaps become motivated enough to install a 5 speed! Tried EOC a few times instead of just N coast engine on but forgot to put in in neutral once. Won't do that again! Isn't the biggest concern a spike in pressure going from Drive into Neutral?
VT247
Old 03-10-2011, 05:17 PM   #15 (permalink)
50 mpg Fiat 500 Project
USPS LLV - '91 Postal Truck LLV
90 day: 14.57 mpg (US)
My Stock S/R - '99 Escort ZX2 S/R
Team ZX2
90 day: 25.7 mpg (US)
Screaming Yellow Zonker - '99 Escort ZX2 S/R
Team ZX2
90 day: 28.68 mpg (US)
Black Beauty - '94 Corvette Convertible LT1
90 day: 18.79 mpg (US)
Blanco - '012 500 1.4L MultiAir 5MT
90 day: 37.96 mpg (US)
something to think about if you have a 904 or 727 torqueflite tranny in your chrysler/dodge/plymouth...
previous to 1966, the torqueflite trans had two pumps, a front and a rear oil pump integrated into the rear of the trans. It was done for the specific purpose of preventing failures while being towed.
if you can find a good pre-66 torqueflite to rebuild, you could rebuild one of those and replace your later model 904 or 727 trans, and you'd be free to engine off coast to your hearts content.
Old 03-10-2011, 09:30 PM   #16 (permalink)
texanidiot25's Avatar
Formula - '96 Formula/Trans-Am
90 day: 19.31 mpg (US)
Question? If they can make a 100% electric lock-up torque-converter,can they make a 100% electric "unlocked"torque-converter,which allows the flywheel to "free-wheel"against the torque-converter? And could they unlock the transmission's tailshaft electromagnetically to allow the transaxle or differential to "free-wheel" eliminating the lubrication requirement for the auto-trans during "coast"?
I've never heard of a 100% electric TC, as opposed to the regular hydraulic, but you could try using electronic hubs like the 4x4s do. They disengage the axle shafts from the wheel in an effort to boost fuel economy. I think Ford used it for some time on the Explorer. Worth looking into, I suppose, but I don't know it's limitations as to when it can and can't be engaged.
Lets see how far it can go
"All I know about music is that not many people ever really hear it. [...] But the man who creates the music is hearing something else, is dealing with the roar rising from the void and imposing order on it as it hits the air. What is evoked in him, then, is of another order, more terrible because it has no words, and triumphant, too, for the same reason. And his triumph, when he triumphs, is ours." -Sonny's Blues
Old 03-11-2011, 01:16 AM   #17 (permalink)
marcusmodder
orange4boy's Avatar
The Golden Egg - '93 Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Prius
90 day: 57 mpg (US)
Originally Posted by Andyman View Post
One modification I would like is to have the torque converter clutch engage in all gears and to stay engaged even when using high loads. I don't understand why it couldn't be engaged whenever the transmission input shaft reaches a reasonable speed such as 1500 RPM. A lot of power is lost by letting the torque converter slip while climbing hills. Maybe the manufacturers are trying to extend the life of the clutch by using it only occasionally and only for light loads.
See: Freezing the Slushbox. Torque Converter on-demand lockup switch.
Effect of gear oil viscosity on transmission efficiency (Metro owners take note) MetroMPG EcoModding Central 36 06-11-2011 04:04 AM
Oil change recommendations? rjacob EcoModding Central 48 08-02-2010 05:04 PM
Larger oil filter for better FE? Gregte DIY / How-to 44 05-22-2010 11:12 PM
Accidental Transmission discovery (bump started my automatic) apgrok1 Hypermiling / EcoDriver's Ed 25 03-10-2008 01:38 PM
