Old 10-30-2009, 09:19 PM   #11 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
How old are we talkin? They used struts in the 60's/70's, I know.
I'd like to think that people might open their eyes at some point... instead, I find it more and more likely that I'll just close mine.
-- Author kept secret.
Je ne veux pas d'une meilleure vie. Je veux être heureux avec celle que j'ai maintenant.
(I do not want a better life. I want to be happy with the one I have now.)
Old 10-30-2009, 09:20 PM   #12 (permalink)
Red CBR - '011 CBR 250R
90 day: 74.21 mpg (US)
99 MAX - '99 Maxima GXE
90 day: 28.35 mpg (US)
Vulcan - '05 Vulcan 500 LTD
90 day: 56.4 mpg (US)
Connected to the center link between the steering box and the idler arm.
That's assuming its independent suspension.
regards
Mech
Old 10-30-2009, 09:21 PM   #13 (permalink)
Mech -
That also assumes it's not Rack/Pinion, which is probably a safe assumption, since I don't believe that was widely used until the 80's-ish.
Old 10-30-2009, 10:58 PM   #14 (permalink)
The 1886 Benz 3 wheeler had a rack and pinion.
I have a nice Franklin mint model or the 1886 Benz with a functional rack and pinion.
Most cars of the era of the picture (probably 1930s) used worm an sector, with a center link to an idler arm. The center link would be stable with the car body and it would only require two linked arms to operate the skirts. Some cars of the era had lights that were connected to the steering so they would point in the direction the wheels were turning.
regards
Mech
The Following 3 Users Say Thank You to Old Mechanic For This Useful Post:
Christ (10-31-2009), some_other_dave (11-03-2009), TEiN (11-01-2009)
Old 10-31-2009, 01:34 AM   #15 (permalink)
Great post, and good information. Where can I get some more info on that Benz?
Old 10-31-2009, 05:15 AM   #16 (permalink)
Benz Patent Motorwagen - Wikipedia, the free encyclopedia
There you go my friend.
His wife Bertha was the first auto mechanic .
regards
Mech
Old 10-31-2009, 07:49 AM   #17 (permalink)
Mica Blue - '05 xA RS 2.0
90 day: 45.16 mpg (US)
Josepha - '08 xD
90 day: 30.76 mpg (US)
Hi,
If the wheel covers only had to move for turns above say 25% of the steering lock, then for normal driving the cover would not need to move from flush. It would move for tighter turns, which usually happen at lower speeds anyway. Also, since it is fixed only to the steering motion (and not the suspension) this would keep it from adding to the unsprung weight.
There is an aerodynamic advantage to having as little air space as possible around the tires -- but having that sort of a snug-fitting fender is a slightly different issue from this kind of pivoting cover. Because unless if you limited the vertical travel of the tire, then a snug-fitting "inner fender" would have to move with the suspension and with the steering, and this would add to the unsprung weight and to the complexity of the design.
So, it depends on how many aspects of the aerodynamics you want/need to address.
Old 10-31-2009, 08:20 AM   #18 (permalink)
JasonG's Avatar
1 Ton - '94 C3500
90 day: 19.26 mpg (US)
Big White Brick - '03 Express Van
90 day: 15.19 mpg (US)
Wonder if this was inspired by Tuckers design from the same era ?
His original design had fenders that turned with the tires so the headlights went around the turn. Supposedly it had a bad rudder effect and was scrapped in the development stage.
Support Bennelson !
I can't understand why my MPG's are so low..........
16000lb, 41' Toy Haulers are rough on FE!
Old 10-31-2009, 03:50 PM   #19 (permalink)
Ford
Ford did this with their Probe-IV but a little different and I think better.
The image you show does not appear to respect "wheel flop"(GM's term not mine),whereas,in a turn,as in the picture,if you encounter a significant bump,the inner fender collides with the wheel arch.
What Ford did,was to let the inner fender( which turns and moves with the wheel) run inboard a bit to clear the arch during full articulation,then a flexible urethane outer membrane actually formed the outer "skin",which was stretched and deformed upon contact with the fender during turns or bumps,returning to a flat panel when the articulation subsided.
I believe Ford claimed a 9% drag reduction,I'd have to double-check that one.
Basjoos has come up with an elegant solution to all this.It's low-tech,fool-proof,and within the means of any modder.Check out his AeroCivic if you haven't already.
Old 10-31-2009, 07:39 PM   #20 (permalink)
chop suey
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
The same era? Struts? Did you guys look at the year?
The guys over at eco-modder are crazy MetroMPG Success Stories 43 12-29-2010 09:01 PM
Hey guys! Looking forward to getting your opinions on this new technology. richar18 Introductions 10 08-30-2009 06:28 PM
What do you guys think about a grill block behind the grill? dremd Aerodynamics 7 02-02-2009 03:03 PM
any 4.0 jeep guys on here? do the deep cycle battery? 95CHERJUST General Efficiency Discussion 2 10-13-2008 11:20 AM
Have you guys noticed any changes in Traffic and Drivers 88CRX EcoModding Central 61 07-03-2008 12:07 PM
