Old 04-15-2010, 12:54 PM   #11 (permalink)
OfficeLinebacker's Avatar
Originally Posted by Billy_BAD_Boy View Post
You are not overtaking, are you?
LOL who would be overtake, poking around like that?
I must admit I do drive in a "spirited" manner on occasion but once I get on the highway into steady state driving, I'm the one being overtaken.
Old 04-15-2010, 01:00 PM   #12 (permalink)
ECO-Evolution
Lazarus's Avatar
Iron Horse (retired) - '97 Iron horse Intrepid
Ninja - '08 Kawasaki 250R
90 day: 76.23 mpg (US)
Originally Posted by PaleMelanesian View Post
I heartily disagree. Go for the lowest rpm you can that will keep you rolling. It's lower than you think.
My 90's Japanese 1.6L 4-cylinder with similar gear ratios:
Runs steady speed just fine down to 25 in 5th gear (1000 rpm).
P&G driving, where I need a little more power, I limit 5th to 30 mph and above.
In your situation above, 35 in 4th or 43 in 5th, my answer would be 35 in 5th.
+1
"Judge a person by their questions rather than their answers."
Old 04-15-2010, 01:11 PM   #13 (permalink)
mcmancuso's Avatar
Green Metro - '99 Chevrolet Metro LSi Sedan
90 day: 32.78 mpg (US)
Metro Vert - '91 Geo Metro LSi Convertible
90 day: 50.52 mpg (US)
A metro Xfi can run at 15mph in 5th gear the Xfi cam and advanced timing lower the power curve significantly. (peak around 2K I think) A cam would be a good investment, as well as a 4-2-1(I think that's right) exhaust header to lower the power band but since you're looking to keep it stock...Can you advance the timing on this car, that should lower the power curve some and give better torque in the low end.
Old 04-15-2010, 01:44 PM   #14 (permalink)
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
About the only time I overtake is when someone raced past me to a red light. I can time it and roll through on the green, when they're just starting from a dead stop.
You will get some shakes and shudders if you try a full-throttle acceleration at such low rpm. Just downshift before you try that.
Old 04-16-2010, 12:12 PM   #15 (permalink)
Master of 140 hamsters
superchow's Avatar
Hamster - '07 Honda Civic EX
90 day: 29.41 mpg (US)
Whooshy Wagon - '04 Volvo V40
90 day: 23.33 mpg (US)
Minotaur - '09 Ford Taurus X SEL
90 day: 19.05 mpg (US)
Or you could try to use higher octane fuel. The ECU should recognise the increased knock resistance and adjust the timing. My 1.8L 07 Civic does just that. (And cost isn't a factor since I actually get more mpg per dollar that way. But it may take some experimenting.)
Old 04-16-2010, 02:21 PM   #16 (permalink)
mcmancuso's Avatar
99 probably does not have that kind of functionality, I'm pretty sure it was rather rare at that time to have an auto advance till it knocks setup in a small/inexpensive car.
Old 04-16-2010, 02:48 PM   #17 (permalink)
...beats walking...
...RULE-OF-THUMB: the highest gear at the lowest rpm that doesn't "lug" the engine.
The Following User Says Thank You to gone-ot For This Useful Post:
cfg83 (04-16-2010)
Old 04-19-2010, 12:52 AM   #18 (permalink)
oldscoob - '87 subaru wagon gl/dr
90 day: 47.06 mpg (US)
Originally Posted by IsaacCarlson View Post
dang...get a low-end cam. That can give you a little more torque on the bottom end. It might be enough to let you use 5th at 35mph. You could also pick up a small industrial turbodiesel and put it in there. Those things make some torque!! I have been looking at some for my pickup and even at full load running against the governor, they only use 1-2 gal per hour. And we don't need to run them at full load and full rev going down the road. I did the math and I gould get 50+ mpg with a small industrial turbodiesel. The reason I saw industrial is because they are more efficient and are designed to WORK all day on a tank of fuel. My dad burns about 1.5 gal/hr in his bobcat.
that is a cool thought..
I saw a ford fiests with a 2cyl turbo diesel at a hot rod forum (yes an oxymoron) clever...
if the car can take the torque, minimal throttle, and vibration that is the winning gear. it is very simple.
the little boxers are famous for this.. I take it to 1200 on a hill, let it rumble.
the diesels could do better, but as the cam wasmentioned, today they try to keep them higher strung like everything else wobbling.
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 1041 07-28-2014 09:19 AM
Can I use a GENERATOR to power an Electric car directly? Nerys Fossil Fuel Free 128 10-01-2012 01:24 AM
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 55 08-20-2012 11:34 PM
I want to get to the bottom of this ethanol killing my mpg Nerys General Efficiency Discussion 175 08-16-2012 08:32 AM
Electric Car Wind Generator Charger demo unit bennelson Fossil Fuel Free 12 04-28-2009 11:20 AM
