Old 05-04-2009, 01:52 PM   #1 (permalink)
Spiffie.org MPGuino not getting past contrast page
Hello,
I recently compeleted the construction of the Spiffie.org v2 kit. When I plug it into my USB port the MPGuino gets stuck on the contrast page. Pressing the buttons gives no response. I updated the source code on the device to the latest version.
I thought that it might be a voltage issue from reading some other posts. I measered the open circuit voltage of my USB port and got 5V. On my board though I get 4.3 volts in the system. I made this measurement by measuring between pins 1 and 2 on the LCD. I also revieved the same reacing when measuring between the hot pin on the LCD and the groudning pin of the voltage regulator. Could my difficulty be a voltage problem? I might have a problem with my buttons, but I would like to rule out this problem before I go on down that path.
Thank You,
Doug Powell
MPGuino release one workspace dcb OpenGauge / MPGuino FE computer 894 10-22-2009 10:07 PM
Pics of my Spiffie.org MPGuino moorecomp OpenGauge / MPGuino FE computer 4 11-14-2008 02:32 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.3.2
