Old 07-06-2009, 10:09 PM   #1 (permalink)
Grasshopper
alohaspirit's Avatar
Makai - '01 Echo 4D Auto
90 day: 34.45 mpg (US)
Mauka - '00 Echo 4D Auto
90 day: 34.5 mpg (US)
Question Stalled while Neutral Coasting
Im not too familiar with EOC
But I was EOnC (Engine On Coasting) down the hill when the engine shut off on me
It happened at the end during a turn when I was going maybe 10 mph or so
I didnt know what to do. So I coasted to a stop and then started the car again.
Luckily only one slow driver was behind me and he went around when I flashed the hazards.
Is this different than EOC?
Is there a way to restart while still in motion.
Past Present Future?
Old 07-06-2009, 10:53 PM   #2 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
Your Tracker should restart while in motion, if you're in neutral. (You were already in N, right?) Not strictly necessary to come to a stop first. Just turn the key.
I used to teach "rolling re-starts" to new drivers as part of a defensive driving curriculum (driving instructor as a part time job when I was going to university). We would intro the concept, explain how a stalled engine affected steering & brakes, and how to bop the gear selector to N to attempt a re-start if it was safe. Then try it out on a quiet road (I'd reach over and key off / on to kill the engine).
Old 07-06-2009, 11:05 PM   #3 (permalink)
Grasshopper
Yeah I was in neutral
it cuts off like that sometimes when I coast slow in neutral
Ill just restart
Old 07-07-2009, 12:28 AM   #4 (permalink)
EcoModding EcoModder
wikityler's Avatar
Gerald - '91 Firefly 3dr
90 day: 40.08 mpg (US)
You should find out why it's stalling. Does the check engine light come on when this happens?
Old 07-07-2009, 12:41 AM   #5 (permalink)
Grasshopper
My check engine light is always on, been like that for years
Old 07-07-2009, 10:01 PM   #6 (permalink)
Driving the TurboWeasel
Get the codes read.
Also, is your fuel level low when it stalls out? 92-93 Bonnevilles stalled when going around sharp corners when the fuel level was low.
2012 Chevrolet Cruze Eco 6MT
Old 07-07-2009, 10:12 PM   #7 (permalink)
Grasshopper
I know the codes (but not offhand), might be egr but thats common with my car
Its not fuel level as Im almost always at least half tank
Old 07-15-2009, 12:32 AM   #8 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Zombie Insight - '00 Insight MT
90 day: 62.82 mpg (US)
Yeah, an EGR problem can cause stalling at idle.
EonC is just the same as idling while rolling.
Get it fixed! A check engine light can cause the ECU to employ a backup fuel map that is richer, uneconomical, and unlikely to stall. I know my Subaru loves to idle high when it's really cold out, or when the CEL is on.
Old 07-15-2009, 01:53 AM   #9 (permalink)
Grasshopper
I know how to fix but I have to remove a lot just to get to it.
If I went to a shop they would probably charge a couple 100
Ill probably leave it.
Ive actually done it a couple more times.
When Im going super slow, ill shift to neutral and itll cut off
Its almost like an automatic EOC.
Old 08-04-2009, 10:52 PM   #10 (permalink)
Certified Duct Tape Tech.
swoody's Avatar
Slow Ride - '00 Civic DX
90 day: 46.32 mpg (US)
Good advice on the 'rolling restarts' Metro. I use that in my daily driving, and I must say it's a pretty nice little boost. I usually will try to time lights so I can EoC up to them, and then restart the car when I need to start accelerating again.
~ If you don't jump with both feet, you don't move at all ~
2000 Civic DX :: 52/50 psi :: Free Warmer Air Intake :: Duct Tape Aero
"Spare the duct tape, spoil the job."
Coasting in gear vs. neutral (fuel cut feature) WTFM8 Hypermiling / EcoDriver's Ed 28 05-29-2011 11:39 AM
Does coasting in neutral or coasting in gear save more gas? xbUser Hypermiling / EcoDriver's Ed 19 10-19-2008 02:28 PM
Coasting in Neutral... what if you can't come to a full stop after? Sean T. Hypermiling / EcoDriver's Ed 16 10-08-2008 01:11 PM
Coasting in Neutral Vs. Coasting in Drive observation fonque Hypermiling / EcoDriver's Ed 21 07-17-2008 04:49 PM
Neutral coasting vs In-Gear coasting Netherby Hypermiling / EcoDriver's Ed 1 06-13-2008 12:53 PM
