Old 02-03-2009, 06:20 AM   #1 (permalink)
Ohh snap
brucey's Avatar
Lesbaru - '00 Outback
90 day: 21.98 mpg (US)
Convertalier - '00 Cavalier Z24 Convertible
90 day: 26.08 mpg (US)
Send a message via AIM to brucey
Started on a belly pan
I got ahold of some sign material and redid my front bumper (it had cracked where some jersey hit me in the parking lot.) into one solid piece instead of 8 signs duct taped together. But it came in a 4X8 sheet and I still had a 4X6 sheet left, what to do?
Smoothness! The car is feels quieter at highway speeds, the only real noise at this point coming from the mirrors and the windshield. Hopefully this helps fuel range too. It will probably be minor though.
The only real downside is while this is some tought stuff, I dont know if its:
"I'm brucey and this is lesbaru and I can make it over that hill." tough. I'm probably going to end up tearing hte material, but doing a fully belly pan in 1/2 inch HPDE like I want to is just too expensive right now. I tore my first belly pan (made from bug screen) in less than a day.
Also: Its not going to melt. I just drove everywhere and then let it idle for 20 minutes and the material wasnt even warm.
Daily Driver
Winter Beast
Old 02-03-2009, 06:52 AM   #2 (permalink)
vectra a - '95 Vectra GLS
90 day: 37.51 mpg (US)
basically you've got two layers of plastic with loads of air channels in between to that's a pretty good heatsink setup...
looks good!
Old 02-03-2009, 07:52 AM   #3 (permalink)
Ohh snap
brucey's Avatar
Its about 4 inches away from my catalytic converter(s) in some places though. Thats what worried me at first. I drove on the highway to get them warmed up and then let it idle while I was doing something else to make sure it wouldnt be a problem.
Daily Driver
Winter Beast
Old 02-03-2009, 08:14 AM   #4 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
It looks like its on the side of the car? It looks nice where ever it is though.
Permanent Aluminum Grill Block and Belly Pan Markmysite EcoModding Central 37 12-20-2011 02:03 PM
Honda Fit Belly Pan Project Fit Aerodynamics 15 03-10-2011 04:32 PM
Metro undertray / belly pan MetroMPG Aerodynamics 33 10-14-2009 11:33 PM
belly pan thrash 2008 lovemysan Aerodynamics 12 09-23-2009 07:51 PM
Mustang belly pan streeter Aerodynamics 13 11-09-2008 03:11 PM
