Old 07-25-2015, 03:04 PM   #1 (permalink)
Lots of Questions
Motor-Rolla - '01 Toyota Corolla LE
90 day: 28.3 mpg (US)
Gaia - '99 Toyota 4Runner SR5 Highlander
90 day: 19.78 mpg (US)
Gaia - Round 2 - '99 Toyota 4runner SR5 Highlander
90 day: 17.3 mpg (US)
The State Doesn't Like My Cat Anymore
I went to my local smog station the other day and he started jacking up my car and looking underneath which I've never seen before for this procedure. After he was done he said that my cat is not compliant with the state. For some reason California decided to change which cats they are OK with and which ones they are not and they didn't grandfather in the invalid ones. I've had this one for multiple smog tests, but now all of a sudden it's a problem.
So... I've been reading up on cats and everywhere I read it seems that it really doesn't effect FE which cat you decide to go with, none of them will make a noticeable difference in FE.
After researching, my only question is this: does it matter if I go with a direct fit for $300 versus a universal for $150? Labor cost doesn't matter, my friend/mechanic will be doing it. I don't have an aftermarket exhaust system, everything is stock. Does one work better, provide better FE, or last longer?
Thanks!
Don't forget to like our Facebook page!
Best EM Quotes:
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9 View Post
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
Old 07-25-2015, 03:40 PM   #2 (permalink)
Mazda CX-5 - '17 Mazda CX-5 Touring
90 day: 26.68 mpg (US)
I would quit CA. Hell would have to freeze over before I changed a perfectly good cat just because a corrupt politician who has a friend in the cat business passed a new law.
How much is it to get a fake smog pass?
ksa8907 (07-27-2015)
Old 07-25-2015, 07:18 PM   #3 (permalink)
90 day: 29.44 mpg (US)
Is it possible that you could go elsewhere and they would not jack up your car?
We have a Facebook page?!
Old 07-25-2015, 08:38 PM   #4 (permalink)
P-hack's Avatar
awesomer - '04 Toyota prius
I think the guy is full of crap, where does it say you have to run out and get a new converter? stick the thing in there and test it already, or deal with the better business bureau and anything else you can come up with.
"Affected converters sold on or before their rescission or withdrawal date, are legal for use
and installation in California. "
http://www.arb.ca.gov/msprog/aftermktcat/catrescind.pdf
If he refuses to do the testing on a legal vehicle, I imagine you could threaten to have his ability to test vehicles for the state removed.
http://www.arb.ca.gov/msprog/aftermk...xemptcat09.pdf
Aftermarket Catalytic Converters
The Following User Says Thank You to P-hack For This Useful Post:
Xist (07-26-2015)
Old 07-26-2015, 02:24 PM   #5 (permalink)
Lots of Questions
I think I'll get a second opinion from a place I used to go to when I lived nearby them. Maybe I won't need to replace the cat if they just do it. Hopefully he won't charge me too much since I already paid the $50 to the first guy (he isn't going to charge me to re-test, so I wasn't worried about it).
Best EM Quotes:
Old 07-26-2015, 06:41 PM   #6 (permalink)
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
200, And more and more of them get caught every year.
The Following User Says Thank You to Baltothewolf For This Useful Post:
redpoint5 (07-27-2015)
Old 07-27-2015, 04:58 AM   #7 (permalink)
one of thOOOse people
twitchy - '98 honda civic dx + sir + ls
90 day: 30.2 mpg (US)
Norman - '14 Ford E-350 EXT
90 day: 16.18 mpg (US)
Silver - '12 VW Golf Base
90 day: 26.1 mpg (US)
Sparta - '19 Honda CB300R
90 day: 84.07 mpg (US)
I'm fairly certain that in CA only the OEM cat is legal. Absolutely no universal or aftermarket cat will pass a visual inspection.
Old 07-27-2015, 08:46 AM   #8 (permalink)
Rat Racer
Fat Charlie's Avatar
90 day: 42.9 mpg (US)
Thanks!
Asking your friend/mechanic to install a part is one thing. Asking him to customize your exhaust is something else. Go direct fit.
Direct fit cats, OE-style O2s and plugs. It's always best to appease your car's machine spirit.
Transmission type Efficiency
Old 07-27-2015, 10:57 AM   #9 (permalink)
"universal" is fine as longas it is cali certified.
Do you see the links at the bottom of magnaflows page:
The Official Site of MagnaFlow Exhaust Products - Exhaust Systems For Trucks, Suv's, American Muscle, Diesel, & Sport Compact Vehicles
All the cali cerifed FOR YOUR SPECIFIC CAR on that page would be "legal" to use. The term universal fit just means it has no flanges so the installation would require some sort of welding.
For the most part magnaflow would have a cali certified universal and a bolt on for most cars. So either one would work.
OP, as long as your mechnic friend is ok welding on exhaust, either one will work just fine. The are the same core. The bolt on just have the proper flanges to directly bolt on to your car as the original one did.
Old 07-27-2015, 12:23 PM   #10 (permalink)
P-hack's Avatar
Why don't you look it up?!? I just posted information from a ca.gov site to the contrary!!!
