Old 11-21-2014, 06:39 PM   #61 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by johnlvs2run View Post
Success! Changing pwr off retries keeps the ultragauge on.
Changing the value from 5 to 33 keeps the ultragauge on for 10 seconds after the toggle (ignition) is switched off. This is plenty of time to switch the toggle back on, and then the ultragauge continues to stay on.
THis seems to work! I have hated the way the thing sometimes shuts off in when I cut the injectors... for three years or so it has been a frustration I just live with... I changed the value from 3 to 15 and it is better. I'll test for a while and maybe raise it further. Thanks!
Old 11-27-2014, 07:57 PM   #62 (permalink)
Liberty Lover
j12piprius's Avatar
pris prius - '12 Toyota plug in prius
90 day: 71.09 mpg (US)
results from kill switch
I'm using plastic wall switch kill switch on the shifter. My previous 2.7 mile route was 45 mpg cold and 62.7 warm. Now I got 63.3 cold and 81.8 warm with the kill switch.
The kill switch sometimes shows err instead of mpg. Changing compatibility > force mpg sensor to MAP didn't help. I will try adjusting compatibility > KWP/9141 optimize.
It would be neat to have a momentary switch that has an adjustable 2 second delay.
Using the kill switch throws off the run time, apparently because the ultragauge doesn't count engine off coasting time. Therefore distance / time results in the average mph being too high. The distance and mpg readings appear to be accurate.
Update: the ultragauge doesn't count distance when the switch is off. Therefore the mpg readings ( miles / gallons ) are too conservative when doing engine off coasting. This is a good reason to keep the switch off as briefly as possible.
Old 11-29-2014, 06:46 PM   #63 (permalink)
RPM
RPM's Avatar
JF - '97 Honda Civic 1.5i LS VTEC (EK3)
90 day: 59.68 mpg (US)
I may be late but can't you just use a front fog light button? It would look 100% OEM, factory quality.
Old 11-29-2014, 11:34 PM   #64 (permalink)
Red Light Avoider
pletby's Avatar
My Civic - '00 Honda Civic DX
90 day: 46 mpg (US)
Right on! Thanks that helps me out. I was just putting up with the display going dead multiple times a trip. Adjusted and tested. Happy dance!
Old 12-02-2014, 01:02 AM   #65 (permalink)
Liberty Lover
j12piprius's Avatar
defogger button
You're quite welcome! I'm glad it helps.
Do you mean the rear window defogger? I like the kill switch on the shifter,
but the defogger button would be convenient to use as a starter button instead.
Old 12-02-2014, 09:11 AM   #66 (permalink)
RPM
RPM's Avatar
No, I meant the area to the left of the steering wheel. Most cars will have at least one blank that can be replaced with a repurposed OEM button, for a nice factory look.
If you repurpose the defogger switch you'd loose that functionality. Better to use a blank space.
edit: not as accessible as the gear lever mount though, that much is true.
Old 01-21-2015, 04:41 PM   #67 (permalink)
Volvo-driving MachYeen
Fingie's Avatar
Neo Volvo - '98 Volvo S70 10V
90 day: 24.98 mpg (US)
I wonder if it is possible to make a kill-switch for a '94 Celica
If you don't make any mistakes in your life,
life itself will be a f*ckup.
With Volvo to Valhalla and back!
Old 01-21-2015, 08:20 PM   #68 (permalink)
Cyborg ECU
I would be shocked if it was not. Yours is a manual transmission? Those 90s cars are so much simpler in electronic engine controls and security that it is probably fairly easy. Find the grounding wire for the injectors make sure that cutting it will not cut anything else critical, then wire the ground through your switch. Done.
Fingie (01-25-2015)
Old 01-25-2015, 05:32 PM   #69 (permalink)
Fingie's Avatar
I am going to take a look at it . That is, if i don't buy something else first
