Old 08-12-2008, 08:50 PM   #1 (permalink)
Steam engine (from exhaust heat)
Has anyone built a small steam engine that could be run from the heat of a car's exhaust manifold? The steam engine/turbine would be used to power a generator/alternator.
Old 08-12-2008, 09:19 PM   #2 (permalink)
The Vue - '03 Vue
90 day: 25.34 mpg (US)
arent steam engines typically... massive
and the energy requirements to keep even a small amount of water would be quite high. It also wouldnt work right away. you would have to boil off the water first, and this wouldn't work in cold weather.
I'm kinda ranting but i think its probably more problems than its worth.
Old 08-12-2008, 09:45 PM   #3 (permalink)
Mr. Blue Tape
azraelswrd's Avatar
AzxA - '06 xA
90 day: 42.72 mpg (US)
Mercedes and a few others have been working on ways to recapture the heat as reusable energy. Stirling engines were an early favorite but they have their own issues.
My 5 pillars of fuel efficiency:
  • driving style
  • aerodynamics
  • tires
  • weight reduction
  • engine maintenance
Old 08-12-2008, 09:54 PM   #4 (permalink)
Ecoformance Engineer
Vince-HX's Avatar
EJ7 - '96 civic Hx
Last 3: 58.02 mpg (US)
what kind of issues with the Sterling engines?
I've been researching them recently and they seem like a great way to reclaim a bit of heat energy.
I would love to make a big version of this one and stick it on my roof. Plenty of sunshine round here
70 mpg or die modding
www.full-race.com
looking forward to seeing what kind of uber-sipper slinks out of the full race skunkworks.
Old 08-12-2008, 10:33 PM   #5 (permalink)
aerostatic
2 ton mother (ship) - '89 Astro CS
Stirling engines have been making some headway lately, mostly being used in solar energy and for marine propulsion/secondary electricty. The main problems are the size to power ratio, potential temperature difference, pistion seals, and engine controls, specifically engine pressure control. The working solar commercial models that I have seen have used molten sodium-- but more practically for automotive use the working fluid would be helium. Plain air could also be used, like the original stirling, but there have been problems with the lubricants oxygenizing and causing explosions. Nasa acutally did some automotive testing with stirling engine for main propulsion in the late 70's and early 80's in a chevette.
Old 08-12-2008, 11:35 PM   #6 (permalink)
FastPlastic's Avatar
98 Cherokee - '98 Cherokee
90 day: 15.69 mpg (US)
ZX7R Ninja - '99 ZX7R Ninja
90 day: 39.56 mpg (US)
I think this is something that is definitely worth looking in to. Especially if you could pull enough power out of it to replace the alternator.
If you use steam would you have to have the boiler inspected?
Adjusted for my driving habits. 80%city/20%Highway.
20mpg city/30mpg highway or bust! Check out my mods so far
Old 08-13-2008, 12:14 AM   #7 (permalink)
Mr. Blue Tape
azraelswrd's Avatar
AzxA - '06 xA
I doubt it can replace the alternator but I can see it replacing an A/C or even for some kind of regenerative charging system for hybrids. Love that prototype in the video -- but I know when people hear "hydrogen" they automatically think of Hindenburg-like images of immolation and fiery coffins of doom.
...guess they didn't know about fuel cells or metal hydride release systems.
  • driving style
  • aerodynamics
  • tires
  • weight reduction
Old 08-13-2008, 12:44 AM   #8 (permalink)
Addicted
bbjsw10's Avatar
bbjsw10 - '91 Metro Xfi
90 day: 51.06 mpg (US)
That demonstrator is cool even to just play with make an rc boat out of it.
Old 08-13-2008, 06:52 AM   #9 (permalink)
So along with these from azrael:
driving style
aerodynamics
tires
weight reduction
engine maintenance
I think we should add steam to the list for a small inexpensive method to reclaim some of our energy. Even in cold whether it should work -- provided you use a shroud to keep some of the air out of the engine compartment. Add a solar reflector to the game -- and POW -- we are getting H-O-T.
We should keep thinking small, inexpensive mods -- because once things get to elaborate they don't make sense from a financial perspective.
Old 08-14-2008, 10:21 PM   #10 (permalink)
Looks like BMW is building a gas / steam hybrid.
BMW Developing a Steam/Gas Hybrid Engine : TreeHugger
Converting Exhaust Heat to Electricity SuperTrooper General Efficiency Discussion 13 03-20-2010 07:03 AM
1992 Metro sedan needs a new engine - What/Where/How - advice appreciated greatly! Crono EcoModding Central 26 11-18-2008 02:42 AM
Heat engine block for efficiency? bennelson EcoModding Central 43 08-12-2008 10:45 PM
Moving air intake into the engine compartment? pasadena_commut Aerodynamics 5 07-25-2008 04:24 PM
Coasting experiment: engine on VS engine off on a fixed route = 12.9% gain MetroMPG Hypermiling / EcoDriver's Ed 6 02-22-2008 09:38 AM
