Old 06-02-2008, 03:57 PM   #51 (permalink)
EcoModding Seige Tank
digitaldissent's Avatar
yarii - '07 Yaris 4dr (auto)
90 day: 41.37 mpg (US)
Bullet Bill - '07 Yaris 2dr hatch
90 day: 36.19 mpg (US)
as far as rotating wheels go, check this out;
I found it from another thread on here
http://www.fluent.com/solutions/auto...bile_wheel.pdf
I am not trying to save the planet, just trying to hurt it a little less
Yaris build thread
what is... http://en.wikipedia.org/wiki/COINTELPRO
Old 06-02-2008, 04:01 PM   #52 (permalink)
EcoModding Minded
Chris D.'s Avatar
Lunar Mist - '02 Tacoma SR5
90 day: 25.31 mpg (US)
Silver Streak - '08 Corolla S
90 day: 38.25 mpg (US)
Send a message via AIM to Chris D.
I wouldnt think that having the vehicle stationary in a wind tunnel is any different than in motion..
your looking at the areodynamic properties of the vehicle, not its drive charactoristics..
Airflow is airflow across the vehicle.. measure your air speeds while doing 55mph then simulate that in the wind tunnel, apply smoke, see what works and what doesn't..
Old 06-02-2008, 04:11 PM   #53 (permalink)
Old Retired R&D Dude
Little Red - '012 Prius c 2 Two
90 day: 26.38 mpg (US)
Transporter - '09 Escape XLS
If your rims are acting as air pumps, moving air out (or in) the side of the wheel,
then putting a wheel skirt over the wheel, may be like holding a solid plate 1/2" in front of your desk fan. The work load on the motor is going to increase.
But, if you had a Moon discs installed on your car? Would the the air pump even be able to start? Since the moon disc is spinning with the wheel, (and not fixed relative to the wheel, like the skirt) the air under the disc shouldn't be moving much and not be a factor at all.
Yeah, it sounds real logical that a skirt should be used with discs.
Did those Gassavers guys that had poor skirt performance have moon discs installed?
Cheers,
Rich
Old 06-02-2008, 04:43 PM   #54 (permalink)
Ex-lurker
i_am_socket's Avatar
Skeeter - '05 Corolla LE
90 day: 35.55 mpg (US)
Not from what I could find in the article
Old 06-03-2008, 10:28 AM   #55 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Originally Posted by trikkonceptz View Post
OK we seem to be the DIY kings, so what would it take to build a wind tunnel? Can a body shop spray booth be used? In which case what kind of air speeds are necessary to obtain results? I am sure we can build the contraption to blow out smoke in streams ...
http://www.aerodynwindtunnel.com/a2.html
Budget wind tunnel for the common man.
The fellow that runs the place worked on the EV1, so he knows what he is talking about.
"You don't fail until you give up. You learn, and move on." - Christ
" Hypermiling is not going slow, it's driving with more intelligence." - UFO
Old 06-03-2008, 03:40 PM   #56 (permalink)
wheels tires
Its a good question and all I can do is relate what I experienced with the CRX.Michelin was touting their Green-X tire in the mid-nineties.Claims were maybe 4-5 % better mpg.They were not available in 13-inch wheel,so $1,000 later I had a set of 14-inch alloy wheels off a CRX Si and Michelin's new wonder donuts.The whole thing was a bust! I never experienced better mpg,either with the low-rolling-resistance of the tires,nor the reduced inertia of the lighter alloy wheels.The tires did have excellent wet and dry traction,not a bad reason to have them,but never delivered on the mpg promise.So all I can say to you is that the experiment didn't work for me.As to the wheel-covers,I did a post installment on Wheels/tires/wheel-covers.It may have some data for you to think about as to what you might expect from a set "of MOONS".Hope it helps,Phil.
Old 06-03-2008, 08:52 PM   #57 (permalink)
- - '010 Prius III w/Navi
Hi D.D.,
Here is a link to the post on Prius Chat about the trim ring modification. Remember, on a standard car you may need to hipermile with verve to keep those brake temps down. No problem on a Prius, as it does most of its braking by the motors.
http://priuschat.com/forums/prius-mo...rim-rings.html
Old 06-03-2008, 08:55 PM   #58 (permalink)
Old 06-04-2008, 12:06 AM   #59 (permalink)
Veggiedynamics
Extreme CRX-HF - '87 CRX custom areo
90 day: 50.8 mpg (US)
Originally Posted by ttoyoda View Post
[I]
I suspect the biggest problem is that in real life, a car is moving on a stationary road surface thru stationary air. All the wind tunnel models I know of a car have the "road" not moving, AND the car not moving, which is different than what really goes on. So the airflow under the car is different in the wind tunnel vs on the road.
To make that less confusing: In real life, the air does not move relative to the road. In the wind tunnel, it does.
When you model aircraft, the "road not moving" problem does not exist.
so what your saying is I need to build a big treadmill in my wind tunnel... ill get right on that
Old 06-04-2008, 09:10 AM   #60 (permalink)
Blue - '-1823 P/U
and be quick about it ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
Old school Honda/Enkei 13" alloys, super light fellfrosch7 For Sale 4 02-08-2008 09:33 PM
