Has anyone ever written step-by-step assembly/ coding instructions for the MPGinuo? I'm about to buy a
SGII, but I like building things, so I might try the 'Gunio first (and my car is pretty much worthless, so i don't mind hacking into the electrics). Also, I have to pull the cluster because the backlights are burned out, and I want to install a switch so I could do the analogue gauge mod on the 'gunio and switch between feeding the tach (all gauges are electric) RPM and MPG data.
Any help is appreciated
Sincerely,
O_O
[oval_overload]
